Old 07-01-2011, 09:22 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
2011 2LT/RS oil change
Going to do my 1st oil change shortly and wanted to be sure on how many quarts to use. I looked in the manual but cannot find it or missed it.
So how many quarts does the V6 take?
FSP tuned: 377/389
Old 07-01-2011, 09:23 AM   #2
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
It takes 6 QTS.
I'm going to be doing my oil change this weekend too!
PsychoZL1 is offline   Reply With Quote
Old 07-01-2011, 09:26 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Originally Posted by PsychoRS View Post
It takes 6 QTS.
Thanks, that is what I thought. But I wanted to be sure are I read somewhere and someone mentioned 8qts.
FSP tuned: 377/389
Old 07-01-2011, 09:27 AM   #4
ABM/IOM
Drives: aqua blue ls and inferno orange ss
8 qts. on the v8 only.
ABM/IOM is offline   Reply With Quote
Old 07-01-2011, 09:28 AM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Ah! Thank you.
FSP tuned: 377/389
Old 07-01-2011, 09:43 AM   #6
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Its in the manual, in the Technical Data chapter under Capacities and Specs.
Old 07-01-2011, 09:53 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Found it, thanks!!
FSP tuned: 377/389
Old 07-01-2011, 10:53 AM   #8
Ten33
Ten33's Avatar
Drives: 2011 2LT RS CGM
How many miles do you have?
Ten33 is offline   Reply With Quote
Old 07-01-2011, 11:12 AM   #9
nyrfan
Let's go Rangers!
nyrfan's Avatar
About 500, plan to change around 1K (mid July).
FSP tuned: 377/389
Old 07-01-2011, 02:04 PM   #10
stray bullitt
Drives: Bentley Continental GT.
Is that when you're supposed to do your first oil change? I hope not, because I've already done 3600 miles, and was just waiting for the dash warning light to tell me.
stray bullitt is offline   Reply With Quote
Old 07-01-2011, 02:09 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
It really depends who you talk to. A lot of people here "suggest" doing <1K it to clean out the "break in" oil / fragments. Some here actually suggest the car performs better too after the 1st oil change, not sure how or why this would be.
I'm following the suggestions plus I want to make sure I have full synthetic in there ASAP.
After that I will change every 5K.
FSP tuned: 377/389
Old 07-01-2011, 02:18 PM   #12
stray bullitt
O.K. thanks. I've been used to new Euro stuff before, and these days they do a year/12000 on the first oil. I remember in the "old" days doing the first flush service to remove swarf from manufacturing, but I understood that engines are made to better tolerances today. Reckon I'll stick some synthetic in at 5k now though.
Old 07-01-2011, 02:33 PM   #13
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
What size is the filter housing nut?
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 07-01-2011, 02:38 PM   #14
Viper595
Redline drop, or go home
Viper595's Avatar
Drives: 2010 Camaro SS
24mm, if I remember correctly.
I can fix cars. I can't fix people.
2010 Camaro SS #123444 - K&N Typhoon CAI, Muffler Delete, MPD-1 Spoiler, Headlight Armor Blackouts. Mods to come: longtubes/tune/flux capacitor
Understeer
is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Viper595 is offline   Reply With Quote
How to see if oil is in intake manifold? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 53 03-23-2011 06:06 PM
1st oil change question rado06 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 09-19-2010 09:10 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
