Drives: 99' Camaro 404 TT Join Date: Sep 2010
805 RWHP 699 RWTQ From a Stock bottom end LS1 Camaro
A.I.R. likes to push the limit !
Can you say 805 RWHP on a Stock Bottom End LS1 ?? We did today ! SO.......... Finished another Project, this time on a 4th Gen Camaro... This car has always been the expermental car. Owner is a good friend of mine, and trusts me and my experiments ! Thx TODD !! Another Successful TEST of POWER. ![]() So.. 2 1/2 years ago when he was bone Stock, we tested out a new custom grind cam to maximize power and still pass emissions, a though task. Born was the E-max Cam, and she passed the dreaded e test in many cars since then with little to no issue, and still providing good gains to people ! So.... Up until 6-8 weeks ago car had STOCK BOTTOM END LS1, Heads / AIR Emax Cam / Fast Intake and the Car put down 455 RWHP and 400 RWTQ. Latest Project was Custom F1-A Procharger Kit w/Front mount Intercooler, leaving everything else the same, Stock Bottom end motor, Same Cam, Heads, Intake Etc... Here are the pics of the end product... Engine BAY BEFORE.... ![]() 1/2 WAY THROUGH THE PROCESS ![]() ![]() AIR CUSTOM TWIN WALBRO 510L Per Hour Total Fuel System Pics. ![]() ![]() ![]() AND THE END RESULTS ! ![]() ![]() ![]() ![]() And the DYNO results... Conditions in the shop are, 5530 elevation Air Temp 84 Deg Bar Pressure 29.94 In Hg Humidt 21 % Calc DA = 8772 ft. Dyno Jet Model 248c 805 RWHP SAE corrected. 661 RWHP Uncorrected. ![]() Were seeing 13psi of boost on a 11 to 1 compression motor. Aprox Sealevel Boost correction would be, 16psi to acheave the same RWHP results at sealevel. Only did 2 pulls on the Dyno... Dyno #1 spun the tires bad and did not get a good reading. Dyno #2 put down 725 RWHP with the power flattening after 5500 rpms showing signs of belt slip. Tigntened down the belt, added some belt dressing, added 2 deg of timing with still alot of room to grow since were on E85, but had a problem with our 2nd pump activation on pull #3 so had to back out. Fixed 2nd pump activation (poor ground connection) , and did a full pass and Dyno #4 is the result... I have no doubt with a cooler engine, more timing, Zero belt slip (cause it's still prevelent on the dyno sheet after 6200 rpms), And re-working the dual -6an feed lines to the stock rail (were running out of fuel based off of the cars wide band running towards 13.0 in the upper rpms), On this patucular setup we were not using bears wideband, though it was hooked up. If the issues mentioned above were not there we could have hit around 850+ WHP, and I'm crazy enough to push it there.. She's currently tuned right now for Aprox 700 rwhp on the street to try and keep the stock internals alive for a while. We decided to give it a glory pass on the Dyno to see what she can do, the numbers outsurpassed any thoughts or expectations we had, And the boys that were at the Dyno stated we broke a few records with this pull of 805 rwhp on this paticular Dyno, The most wheel hp they can recall on a stock bottom end. We had a great day today ! Time to hit the sack ! Clint |
NorCalCamaros.com
Great job guys! Sweet ride for sure.....
Jason |
![]() ![]() Drives: 2011 Challenger SRT8 6.4L 392 Hemi Join Date: Jul 2010
Great job with build but if it last more than a few thousand miles of decent running then I will be shocked.
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
I hope its just a dyno queen, but on the other hand if the bottom end gives out then you could go full Forged and push over 1000RWHP. Great job, and it looks great.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS, 2008 Heritage 300C Join Date: Jun 2009
Anyways, nice numbers. I don't see it lasting very long though.
#6 |
Vroom
Awesome numbers guys!
LSX, Boost, 9", TH400
xxxxhp - xxxtrq |
#7 |
![]() ![]() ![]() ![]() Drives: bug Join Date: May 2009
Nice build and I cant wait for the track results.
#8 | |
^^. I agree there's a risk, We were not planning on seeing this boost level right out of the gate, but since we are we gave it a glory pass on the Dyno to see what she will do. She's de-tuned now to about 700whp corrected. Were going to make a few adjustments, throw the 805 tune back in and see what kind of times she will do at the track. Don't know how we will hook but she should trap 130+ at our 8,000+ average DA here in Denver. Clint |
#9 |
I refuse to go smurfy
Drives: 2009 Challenger SRT8, 2010 Camaro Join Date: Nov 2009
nice!
![]() -Bill...the Camaro was my wifes, now she's got a minivan Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
| Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
| Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
