Old 07-03-2011, 05:37 PM   #1
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Started Detailing but didn't finish
I started Detailing the car today with my Adam's products. I washed, dried and then decided to use the SHR/Revive/Butterwax by hand. I am about half way done and ran out of steam. I want to continue tomorrow so I sprayed the hand pads with detail spray and put them in a zip lock bag. Is that ok to do? I was thinking it would be the same as a paint roller. If you are in between painting you can put the roller in a zip lock bag and reuse the next day.
redirish is offline   Reply With Quote
Old 07-03-2011, 05:51 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Not sure if these pads are meant to be put in a zip lock bag. I know that if they have even the slightest of moisture, they will grow mold. The Adam's products are meant to work hand in hand, so that when you spray Detail Spray on the pad, it re-activates the SHR on the orange pad, or FMP on the white pad, etc.
Old 07-03-2011, 07:09 PM   #3
redirish
redirish's Avatar
I just cleaned everything. Just wondering if there is an option if you are using the pads and do not finish in the same day. I hope the pads are dry by tomorrow.
BMR Products Now Available with DuraChrome Finish! Rich D Suspension / Chassis / Brakes 1 08-18-2010 09:18 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Fit and Finish Camaro Goon 5th Gen Camaro SS LS LT General Discussions 76 12-19-2007 06:28 PM
