Old 07-13-2011, 12:05 PM   #1
69bluess
Drives: 02 SOM Z28... 69 SS camaro
2002 Camaro SOM 6spd 43k original miles 600+whp Lots of pics over $20k in just mods
Have decided its time to move on to a new project so time to let someone else enjoy my pride and joy as much as i have. She is a 2002 Camaro 35Th Anniv. edition T-top 6 speed car. Color is Sunset Orange Metallic and The car has 43788 original miles. I had a goal when i originally bought The car to see 500whp on The stock bottom on motor only. After alot of planning and work i reached my goal with dyno numbers of 506whp and 438wtq on motor. The car also has a nitrous express shark nozzle wet kit. It currently has The nitrous set to 100hp. On The 100hp hit The car made 609whp and 603wtq. As far as track times go I've personally driven The car to a 11.16@124mph on motor and 10.69@129mph on The 100 shot. The car ran out of gear on The 26" tires so i went to a 28" mickey Thompson et drag. first time out on The new tires i went a 10.85@130mph with a 1.49 60' on an unprepped track for a king of street event and got kicked out for no cage. I know The car can go some 10.4X's with some good driving on The 100 shot. The car is not stripped in any way and has had only The best of The best bought for it. I have over $20k in aftermarket parts alone in The car. in street trim i have a full set of aftermarket black 17" Z06 wheels wrapped in sumitomo rubbber. I also have extra pair of 17" Z06 true GM speedline wheels with Mickey Thompson ET street tires. For the drag strip i have Weld RTS aluminum racing wheels. The Car is a true street car and has never been trailered to the track. My local track is a 40 min drive one way. I have made many of trips to the track, get there set my tire pressure, make multiple passes, air my tires back up and drive the car home never worrying about anything. I have not been afraid to get in the car and drive anywhere. Here's a list of everything done to the car.
-monster level 3 clutch (~7000 miles)
-new clutch slave at time of clutch
-tick clutch master cylinder
-D&D T56 viper build (less than 5000 miles)
-Remote bleader
-Quick time blow proof bell housing
-PST 1200hp 3.5in Aluminum Drive Shaft
-Pro 5.0 shifter
-Poly Trans mount
-Original Stock bottom 346 ls6 with Katech rod bolts and pistons fly cut .100" for valve clearence
-T.E.A. ported trick flow 215 heads milled to 58cc (less than 1000 miles)
-comp forged one piece push rods
-cometic .040" head gaskets
-Pat G custom ground cam 239/243 .624"/.624" 113+3 LSA
-texas speed ported ls6 oil pump
-ARP head bolts
-ls2 timing chain
-new cam and cranks sprockets
-Morel Hydraulic Lifters Link Bar Setup
-Yella Terra Ultralite Roller Rockers
-katech rod bolts
-kooks Stainless 1 7/8-2" long tubes with 3.5" collectors
-Kooks stainless 3.5 to 4" Y
-QTP Stainless 4" cutout pipe
-DMH 4" electric cutout
-Magnaflow cat back
-Fast 102 ported by tony mamo
-Nick Williams 102 throttle body
-mototron 60lb injectors
-LS2 fuel rail
-LS2 fuel rail adapter set
-Fast toys 104mm air lid
-Custom bellows for larger air lid
-K&N air filter
-Katech belt tensioner
-ASP underdrive pulley
-ARP balancer bolt
-racetronix fuel pump and hot wire kit
-dyno tune (Tracey Scott of Cincy Speed)
-poly motor mounts
-NX nitrous kit (shark nozzle system good to 250hp)
-Harris speed works nitrous bottle heater
-Harris speed works nitrous botle brackets
-Harris speed works nitrous purge kit
-nitrous spare tire bottle mount
-zex remote bottle opener
-Innovate digital nitrous gauge
-Harris speed works nitrous ash tray switch panel
-Custom remote opener/nitrous gauge panel in console
-Weld RTS racing wheels
-Mickey Thompson 28x10.5 slicks (only two track passes)
-Mickey Thompson Tubes
-wheel screw kit
-GM 17" Z06 speed line wheels
-Mickey thompson Et Street radials 17"
-Spohn pro series chrome moly torque arm
-Spohn chrome moly adjustable panhard
-spohn lca relocation brackets
-Spohn chromemoly weld in subframe connectors
-umi adjustable lca's poly one end rod end the other
-Strange single adjustable rear shocks
-Eibach sportline lowering springs
-slp roll control
-Autometer dual pillar pod
-Innovate wideband LC-1
-Autometer electronic sport comp fuel pressure gauge
-Moser 12 bolt gurdled aluminum cover 4 channel abs, auburn posi, 30 spline moser axles, 4.10 gears
-ARP wheel studs
-Hawk brake pads
I have reciepts for most all parts on the car. Also have the original window sticker. Car has scene nothing but mobil one full synthetic oil.
Here's a link for more photos of the car
http://s96.photobucket.com/albums/l193/gearheadls1/
Im looking to get $21500obo, may consider some trades. in the market for a corvette, G8, CTS V, or 5th Gen camaro. Have extra cash if needed for the right deal.
DYNO VIDEO
Heres a idle video and clip from the track, just click the pics
69bluess is offline   Reply With Quote
Old 07-14-2011, 10:21 AM   #2
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Nice car, GLWS
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 07-15-2011, 08:15 AM   #3
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
great looking car...
and at this price.... should have no problem getting rid of.
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
1999 HUGGER SS SOLD :(
400rwhp (3375lbs)
2002 YELLOW Z06 SOLD :(
360rwhp (3040lbs)
2013 CAMARO ZL1 COMMING SOON
M6HuggerSS is offline   Reply With Quote
Old 07-20-2011, 09:40 AM   #4
69bluess
Originally Posted by Joebot8484 View Post
Nice car, GLWS
thanks! hopefully will find her a good home soon
Old 07-26-2011, 12:12 PM   #5
69bluess
any interest?
Old 07-26-2011, 12:21 PM   #6
testmule
Drives: 2011 camaro
Nice car. But to the average consumer very few of the upgrades mean anything.
I would be surprised if you get any offer above $14,000.00.
I hope I'm wrong.
testmule is offline   Reply With Quote
Old 07-26-2011, 11:54 PM   #7
69bluess
I hope I'm wrong.
i've already been offered $18k for the car. I know its gonna take someone of particular interest in how the car is built and what it is to buy the car.
Old 07-27-2011, 12:11 AM   #8
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
What a beaut... Best of luck with the sale man, don't give an inch on that price.
Old 07-27-2011, 04:58 PM   #9
testmule
Drives: 2011 camaro
Take it!
Old 08-02-2011, 09:33 AM   #10
69bluess
bump it up
Old 08-08-2011, 10:41 PM   #11
69bluess
ttt...
Old 08-25-2011, 09:32 AM   #12
69bluess
ttt...
Old 08-25-2011, 10:27 AM   #13
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Wow.. had not noticed your post till now.. Very very nice and well thought out build. I am amazed that you are not getting serious offers on this and understand you put your bottom line price right out there. Good luck with the sale and someone will be getting a fun car that should perform very well for a long time.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 08-26-2011, 09:36 AM   #14
69bluess
thanks appreciate the kind words. Looked like was gonna have a quick sale when first listing and the offers have just dissapeared, not a good sellers market at all right now.
