07-15-2011, 08:48 PM | #1 |
Drives: 2010 White/IOM 2SS/RS M6 Join Date: Jul 2010
FAST 102 on a 416ci LS3?
I'm either putting a stock ported intake and throttle body or a FAST 102/102 set up on the 416 that's getting built for my car. I've seen mixed results and I can't decide if it's worth it to spend the extra money on the FAST set up. It'll also have ported stock heads and an aggressive cam. Any thoughts?
2010 White/IOM Camaro 2SS/RS M6
07-15-2011, 10:21 PM | #2 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Worked well for my buddies ls7? But that was a 427 ZO6 corvette
07-16-2011, 10:08 AM | #3 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Without a doubt you should get it on a 416, don't forget to match the intake runners on the heads to the runners on the intake. It's really easy with a dremel tool.
07-16-2011, 10:46 AM | #4 |
Drives: 2002 Camaro SS Join Date: Jul 2009
I would go with the Fast 102 on a 416. Will work well with the extra cubes.
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms |
07-16-2011, 11:02 AM | #5 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
07-16-2011, 05:17 PM | #6 |
Well damnit I guess I'll have to save up some extra. Thanks guys.
07-18-2011, 07:03 AM | #7 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
i have a fast102 that was on my car for 1 summer, its just sitting here on another ls3 engine on the engine stand,, id sell it to you for $550 plus your stock intake, the fast also has the spacers needed to run the stock short ls3 style injectors so it is ready to go.
jay
Similar Threads | ||||
Fast 102 mm intakes | cmyzfly | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 3 | 01-03-2013 06:29 AM |
LS7 FAST 102 Intake for sale. | ucanthangwme | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 9 | 05-10-2011 11:32 PM |
Fast 102 install? | summitss/rsls3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 04-05-2011 12:10 PM |
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List | GQ4Life | Dragstrip and Launch Techniques Discussion | 17 | 07-07-2010 12:31 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
