Old 07-18-2011, 10:36 AM   #1
pdesanctis
i like to go fast
Drives: 2011 SS
Dealer only put 7 quarts of oil in my SS
Has anyone else checked their service receipt to see that the dealer only put 7 quarts in, it should be 8 quarts.
pdesanctis is offline   Reply With Quote
Old 07-18-2011, 11:04 AM   #2
Blake_GM
Blake_GM's Avatar
Drives: 2011 Camaro 2SS/RS in IBM
I checked my invoice from my first change @ 1,500 miles. It was also 7 quarts with filter change. I went out and checked the book, which indeed says 8 quarts with filter change and then promptly checked my dipstick and it was showing full and still fairly clean.
Blake_GM is offline   Reply With Quote
Old 07-18-2011, 11:30 AM   #3
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Well they either did not change the filter and used 7 OR they did it right and only charged for 7 when they pumped 8. If you read your manual before you go your smarter than them.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 07-18-2011, 11:36 AM   #4
Blake_GM
Blake_GM's Avatar
Luckily I was able to watch him change the oil from the waiting area up on the lift, he definitely replaced the filter, watched him spin the old one off take the new one out of the box, and spin the new one on.
I'm going to keep an eye on the oil level though, but it was completely full/within correct full range according to the dipstick.
Edit: Unfortunately, I didn't stick around in the waiting area to watch him fill it up with oil. Not sure how many quarts he put in, invoice said 7, however.
Old 07-18-2011, 11:38 AM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Buy 7 get one free?
Old 07-18-2011, 12:38 PM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
My dealership put 6 qts on the invoice to lower the price. The tech said 8 went in. Of course I checked and it was full.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 07-18-2011, 01:27 PM   #7
NavyDood
Retired Navy
Drives: 2010 2SS/RS
Just check the dipstick. If it is full and they charged you for less than needed, you came out the winner.
NavyDood is offline   Reply With Quote
Old 07-18-2011, 03:01 PM   #8
pdesanctis
i like to go fast
Drives: 2011 SS
It was an old invoice. The invoice being the 1st oil change I did with the car. The last several oil changes I did on my drive way
Just a heads up
Old 07-27-2011, 04:01 PM   #9
kbui
kbui's Avatar
Drives: 85 Vette, 07 Escalade ESV, 03 GMC,
My first free oil change at the dealer was 8 qts as I was there watching him putting them in, but the receipt reads 6 qts. Turns out it's the standard oil change item on their computer on the printout....
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop
Whiteside Customs Super Street 2 Package w/ coilovers
BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars
MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels
kbui is offline   Reply With Quote
Old 08-05-2011, 09:55 PM   #10
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
The engine might hold eight quarts when filled dry. There may be enough residual oil left behind that a drain only dumps 7 quarts. My Harleys are the same way. The engine holds 4 quarts, but an oil change is only 3.5. It states that in the owner's manual not to overfill because of the oil that stays behind inside the engine.
bannonm is offline   Reply With Quote
Old 08-05-2011, 10:04 PM   #11
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
yea right
yea that residual oil left behing was that last quart in the engine that they failed to let drain out prior to putting the drain plug back in.Saves alot over the hundreds or more cars that they service each month.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 168 08-07-2024 02:29 PM
How to see if oil is in intake manifold? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 53 03-23-2011 06:06 PM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
