Old 07-19-2011, 01:02 PM   #1
bmorecam
what to use to hold stillen splitter in place?
So I used a stronger 3m tape on the sides as suggested by some members here but is still not holding in place. What about sillicone? and what type of sillicone am I suppose to use, it seem to be over 10 different type at my local auto shop. Any other suggestion? not too good when it come to this type of things.
Old 07-19-2011, 01:14 PM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I used black silicone from ACO. Good for 50 years. Red Devil was the brand. Matched the non-painted Stillen perfectly. I put a bead around all the edges that touch the front fascia.
Old 07-19-2011, 01:17 PM   #3
bmorecam
how long does it take to dry?
Old 07-19-2011, 01:20 PM   #4
rtcat600man
less than 24 hours. I did not use it like a glue but more to help seal up the edges.
Old 07-19-2011, 01:23 PM   #5
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I love the look of that. It's officially on my list. Pretty affordable too.
OOLIE is offline   Reply With Quote
Old 07-19-2011, 01:42 PM   #6
bmorecam
ohh.. ok.. now I see. because there's that gap right in the middle of the curve right? I wonder if I can use the sillicone and seal it properly without making it look like a kid did it. You seal it just like if you was to seal around your bathtub or something similar right?
Thanks.
Old 07-19-2011, 01:51 PM   #7
rtcat600man
Thanks.
Now you got it. I ran a bead (very small) around the edge and smoothed it out with my finger to try and make it look good. Caulking and silicone is not my specialty, but it did turn out decent.
Old 07-19-2011, 02:16 PM   #8
KMPrenger
KMPrenger's Avatar
Hrrmm...I thought maybe this thing had some screw/rivet points in the middle that could be used to hold it n place. It would be hard for me to trust just tape/glue even though I know many of you have had good results with just that so far.
Old 07-19-2011, 02:20 PM   #9
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
Would the silicon option work on the Gm GFX splitter in your opinion? The front of the splitter is held by rivits but the sides near the wheels are purley held by 3M tape and mine have repeadidly come off. Not sure what other option to use. :/
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 07-19-2011, 02:24 PM   #10
bmorecam
The middle 3 posts are not the problem as I even used larger screws and 2 on each post to hold the splitter in place, its just the sides that I am having problems with. I wouldn't dare just use tape and sillicone to hold the whole thing in place.
Old 07-19-2011, 02:46 PM   #11
J.L.TYCHE
Tampa Gulf Coast Family
J.L.TYCHE's Avatar
Drives: 2011 Corvette
Did you clean the area to be taped with achohol,the 3M tape works very well
J.L.TYCHE is offline   Reply With Quote
Old 07-19-2011, 02:49 PM   #12
UT-Engineer
Just Cruisin'
Yea, it still doesnt work. It will hold for a day or so but will peel by day 3+.
Old 07-19-2011, 03:28 PM   #13
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
I still havent installed mine yet. I know....
Im just not sure if i will mess up or not.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 07-19-2011, 03:49 PM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Mine is an SS, but the problems are the same. My passenger side corner kept coming loose. My install guy used a higher quality tape. I think the tape has a hard time holding to plastics. I have had the same issue on my rear skirt pieces behind the rear wheels. The main side skirts where it sticks to metal seems OK. Did you use a wax remover where the tape makes contact? If not, I would try this and use adhesion promoter on the fascia as well. You will likely have to remove the splitter though. My ultimate fix was a different splitter, but because of other paint issues.
New Havoc Diffuser/Rockers and Stillen Splitter cfcoates Camaro Photos | Spyshots | Video | Media Gallery 45 03-11-2012 10:42 AM
Rally yellow Stillen V6 splitter Topher5000 Local Marketplace 6 10-10-2011 07:26 PM
Stillen Front splitter - V6 masterofpuppets Local Marketplace 12 08-30-2011 03:50 AM
stillen splitter installed 21010 Cosmetics and Lighting Modification Discussions 21 04-18-2011 10:35 PM
Installed the V6 Stillen splitter too! LosingReality Cosmetics and Lighting Modification Discussions 29 09-21-2010 12:52 PM
