Old 07-20-2011, 10:43 PM   #1
lolcamaro
Drives: 2011 black camaro
opened door onto sidewalk level and scratched up underside of door pretty bad
Cosmetically, it's impossible to tell obviously because you would have to be looking from underneath the car.
The only thing I'm worried about is will this rust up and cause a problem or can I just leave it?
Thanks!
lolcamaro is offline   Reply With Quote
Old 07-20-2011, 10:46 PM   #2
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Thanks!
Fix it. especially based on your location.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-20-2011, 11:03 PM   #3
lolcamaro
what does fixing it entail?
Old 07-20-2011, 11:06 PM   #4
KSFastah
Whatevah
KSFastah's Avatar
Drives: 2011 Camaro 1SS/RS M6
Probably sanding the affected area down....re-priming it...and repainting it...get it sealed so it doesn't begin to flake or peel from that location...and to keep the water out and hence the rust from starting.
KSFastah is offline   Reply With Quote
Old 07-20-2011, 11:18 PM   #5
lolcamaro
what would happen if I just left it?
Old 07-20-2011, 11:20 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Why would you do that? Go to a body shop and get it fixed right so it doesn't rust!
Rock-It Man is offline   Reply With Quote
Old 07-20-2011, 11:36 PM   #7
lolcamaro
would it work to just toss some touch up paint on it?
Old 07-20-2011, 11:51 PM   #8
lolcamaro
whats the easiest way to deal with this?
Old 07-21-2011, 12:07 AM   #9
lolcamaro
will this work?
http://www.amazon.com/Dupli-Color-SF...219668&sr=8-28
Old 07-21-2011, 10:10 AM   #10
Kermit1
Kermit1's Avatar
Drives: 2011 Callaway 2SS/RS
I feel your pain, I had added mud guards and recently noticed I had backed into a curb. Fortunately it on the bottom outer edge and they are made of plastic so no rust issue. Just ugly if you lay down and look.:(
Kermit1 is offline   Reply With Quote
