Old 07-21-2011, 09:19 AM   #1
DevilKnightFalcon
Drives: 2010 Camaro 2LT/RS
Send a message via AIM to DevilKnightFalcon Send a message via Yahoo to DevilKnightFalcon
Can GM detect a V6 reflash?
I saw the articles about how GM now has a way of determining the reflash history for V8s. Does anyone know if they have a similar technique for the V6? All of the documents i've seen specifically state that they apply to the V8 only.
DevilKnightFalcon is offline   Reply With Quote
Old 07-21-2011, 09:25 AM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
It has been reported on other threads that NO, it cannot be detected.
Old 07-21-2011, 09:41 AM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
its been reported that GM isnt as worried about V6 reflashes and that certain dealers have said they cant check it, but where has GM stepped in and said that they cant scan the reflashes?
I piss excellence
and fart awesomeness
Old 07-21-2011, 09:50 AM   #4
rtcat600man
They haven't, that is why I said others have posted that they cannot see the reflash. But I personally don't believe that.
If you’re worried about tuning and being caught then one should not do it in the first place.
Old 07-21-2011, 10:02 AM   #5
CamaroSpike23
Truth Enforcer
thats my whole point . everyone is going off of regurgitated info and spewing it out as gospel.
I can tell you from speaking with GM engineers and the guys who wrote the programming on the V8 and V6 ECM's that if they want to, they can find a reflash. resetting the counter only bypasses the dealer level of comparing the flash counter to the "supposed" # of flashes for the car.
but when you tune these cars, and flash back, you still leave traces of the changes in the memory.
now, do I think a large number of people with v6 cars will have their warranty denied because of a tune? hell no. GM isn't as focused on warranty claims for the V6 dealing with aftermarket tunes. their priorities lay with the SS cars. now, if you blow the motor in the v6 after tuning somehow and GM does an investigation, chances are very high that they'll find that you tuned the car. but, the failure rate on the V6 engine is not significant enough for the majority of v6 owners to worry about voiding their warranty.
but at the end of the day, you gotta pay to play.
which makes me ask the question of aftermarket tuners, why no warranty to back up your product?
nearly every other modification out there has some sort of warranty to cover it if it fails or causes something else to fail... except a tune.
most all the tuners market a variant of a "hidden" tune or just say "flash it back to stock, the dealer will never know" but what happens to the guy who blows his motor 40 miles from home and doesnt have his tuner in the car? flatbed comes and gets the car, do you think the dealer is going to sit there and watch as you flash back to stock?
I piss excellence
Old 07-21-2011, 10:11 AM   #6
rtcat600man
exactly......
Old 07-21-2011, 10:13 AM   #7
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Wants a tune but I'm scared GM will decline a warranty claim if one came up . Not afraid to admit it .
bee sting is offline   Reply With Quote
Old 07-21-2011, 10:17 AM   #8
The_Blur
Moderator
The_Blur's Avatar
You're asking the wrong question. The real question asks, "Do they care?"
warn 145:159 ban
Old 07-21-2011, 10:19 AM   #9
CamaroSpike23
Truth Enforcer
the biggest issue is that you would have to sufficiently mess up the engine enough for them to "want" to look into the tuning.
I piss excellence
Old 07-21-2011, 02:14 PM   #10
bill@hptuners
Drives: grand prix
Do they care? Probably not
Could they tell if they really wanted to, yes.
I think the whole "can they tell" argument goes back to diesels, with tuning you can add a hundred hp/ftlb and things will simply start breaking. On a non boosted DI motor its not going to add a huge amount of hp/tq so they likely haven't seen much breakage thus far. If it became a problem the bean counters might start looking closer at it to see if its worth their time to investigate further.
bill@hptuners is offline   Reply With Quote
Old 07-22-2011, 07:17 AM   #11
CamaroSpike23
Truth Enforcer
I piss excellence
Old 07-22-2011, 11:14 AM   #12
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
all newer GM vehicles have a cvn(calibration verification number) stored in the pcm / tcm , anytime an aftermarket tune is applied to the module the cvn # changes and will no longer match the number that gm has stored in its data-base
if you show up at the dealer with a bad engine or trans the cvn# is required before a major repair or replacement of the engine/trans can be approved by gm,, the dealer has no control over this. if the numbers dont match the warranty is automatically void and the repair and any time the tech has in the vehicle can become the customer responsibility.
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 387 09-19-2019 06:53 PM
V6 looks better than a V8? ibeck 5th Gen Camaro SS LS LT General Discussions 5 01-18-2011 12:27 PM
V6 Cami VS V6 Genesis..LOL MillerTime Chevy Camaro vs... 226 06-09-2010 09:00 AM
V8 appearance vs. V6 Discussion! jpsuperman81 5th Gen Camaro SS LS LT General Discussions 19 08-08-2009 09:01 AM
