![]() Drives: Black 2010 2SSRS Join Date: Jul 2011
Need to know..help me clear the air...fuse pull
Do I need to do the fuse pull on my ls3. Keep reading so much about this. Had my car for 2 years and been putting 93 in it ever since Ive had it. And also is getting a handheld tuner like diablosport worth it. I already have axleback exhaust,plan on getting a cai,possibly tune and thats it.Just wanna know how necessary this fuse pull thing is, dont wanna have power somewhere that im not getting. any answers much appreciated
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
If your dealer filled the car with fuel they most likely put in 87 octane, so it is not a bad idea unless you know for sure. Either way the fuse pull is not a big deal and easy to do. I did it myself for the heck of it.
Darth-Z
Drives: 2013 Camaro ZL1 Blk/Blk Join Date: Sep 2010
First, a fuse pull will not hurt you at all. It is only going to reset the computer to the high fuel map.
Second, get a CAI (Cold Air Inductions are real nice and quick install), as it will give you a nice boost in power and give the car the sound it should have when you stomp on it. Third, I would not get a handheld tuner. You are better off spending the money to go to a shop and have it done professionally. Most reputable shops will update your tune if you buy new parts from them that will require it.
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
The fuse pull should be tried whenever you feel like maybe it's a bit sluggish. You can easily get a bad tank of gas even if 93 octane. If the car senses lower quality or octane gas it kicks it down to low octane tables. It will NOT relearn on it's own.Run down your current tank of gas then fill up with quality 93 octane like Shell. Pull out fuse #5 & #20 for several hours at least then pop them back in and the computer will reset to high octane tables.
| ***Updated Fuse Pull info, confirmed*** | PQ | 5th Gen Camaro SS LS LT General Discussions | 228 | 05-07-2016 01:19 AM |
| OIL CATCH CANS | john468 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 5 | 09-16-2010 02:02 PM |
| Anniversary....... August, 2009.... fuse pull month.......... | PQ | 5th Gen Camaro SS LS LT General Discussions | 41 | 08-03-2010 05:46 PM |
| AirAid Cold Air Intake anyone? | FLYNNZL1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 09:05 PM |
| Air Intake Information for GM's 3.6L V6 | Airaid Filters | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 91 | 10-27-2009 07:26 AM |
