Old 07-25-2011, 05:34 AM   #1
Blk_SS
Drives: black on black 2SS/RS
what oil weight are you running
for the S/C and turbo guy did you change the weight on your car or you leave it at 5w30?? please list if your car S/C or turbo and what weight you use if you change it
Blk_SS is offline   Reply With Quote
Old 07-25-2011, 08:48 AM   #2
epstein
Drives: SS/RS
Send a message via AIM to epstein
Same Mobil 1...... no issues,.... change every 3k or less
epstein is offline   Reply With Quote
Old 07-25-2011, 11:36 AM   #3
SilverIceman
SilverIceman's Avatar
Drives: Camaro SS SIM
Supercharged, changed to 10w30 Mobil 1.
I don't drive it in the winter.
SilverIceman is offline   Reply With Quote
Old 07-27-2011, 10:42 AM   #4
Xander
Xander's Avatar
Drives: ADM Built 740RWHP 2SS/RS
Mobil 1 15W50 in the summer and 10w30 in the winter.
Xander is offline   Reply With Quote
Old 07-27-2011, 12:02 PM   #5
old motorhead
Drives: Maggie blown LS3 vette
If your engine is stock, use what GM recommends. They set the clearances. The fact that you have a supercharger on top doesn't change anything. "Heavier" oil isn't any tougher....it's just harder to get it where it needs to go. More oil pressure isn't necessarily better.
old motorhead is offline   Reply With Quote
Old 07-27-2011, 12:27 PM   #6
GEN-IV
Right Cam
GEN-IV's Avatar
Drives: 2010 LS3 / 79 Z28
10W30 Mobil 1.
GM balances durability and fuel economy in their selection of oil, my concerns do not include fuel economy. 10W30 does have a higher film strength than 5W30, and if 5W30 isn't too "thick" at -20F, then 10W30 is just fine the rest of the year.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 07-27-2011, 12:32 PM   #7
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
15W50 Mobil 1
bumblebeecamaro is offline   Reply With Quote
Old 07-28-2011, 06:57 AM   #8
SilverIceman
My builder/tuner recommended it. I'll pass your concerns along.
Old 07-28-2011, 08:17 AM   #9
old motorhead
No concerns. Very little difference between the 5W and 10W 30. They're both 30 wt oils at operating temperature. My comments were aimed at the guys running 40 and 50 wt oils in a motor designed for 30 wt oil. I run 50 wt oil in a built LS2 motor simply because that's what the builder told me to run. He set the clearances. The General built my LS3. He set the clearances. He told me to run a 30 wt oil. Hmmmm.
I do run heavier oils in some high mileage (200,000+) engines. No way would I do it in a stock, low mile, LS engine.
Old 07-28-2011, 10:38 AM   #10
GEN-IV
Right Cam
GEN-IV's Avatar
As a point of reference, Ford recommends 5W20 for the 5.0 GT and 5W50 for the Boss 302 and GT500.
Old 07-28-2011, 11:32 AM   #11
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
The 15w-50 Mobil1 is a different formulation, it has a higher anti-wear additive package and still has zinc... Proven to stand up better in the harsher environments of the turbo and SC engines... Every oil viscosity has it own shear strength and pressure limits etc.
I am running 15w-50 btw...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 02-03-2012, 12:03 PM   #12
CRUSHER2SS
CRUSHER2SS's Avatar
Drives: 2010 Camaro 2SS/RS
Anyone else care to post up what oil your running with a supercharger? Builders? ADM, Jannetty, Lingenfelter, Livernoise..........? What do you recommend?
"We don't stop playing because we grow old; we grow old because we stop playing"
2010 2SS/RS L99-Black-658RWHP 582Tq - Magnuson TVS 2300 SC -w/OD COG
LS3 Conversion - GT9 CAM - Ported Heads
ADM-Race CAI - GM ZL1 Heater Hose Kit- KB BAP
Kooks-1 7/8 LT Headers, Corsa-Cat-back
Tune ECM & TCM - VMAX Ported TB - Posi Mod -
Pfadt - Drag Coilovers, Motor mnts, Trailing Arms, Camber Plate, Control Arm Stiffeners, F&R Bushing, Pfadt ZL1 Balance/Sway bars, Sub frame, Diff bushing
Nitto-NT05R DRs 315/35R20
ZL1 Prototype Wheels (10's Ft & 11s Rear) - RB Front Rotors
MPD1 Spoiler
CRUSHER2SS is offline   Reply With Quote
Old 02-03-2012, 12:24 PM   #13
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
10w30 Mobil 1, changed after every track day (usually every 1-2 weeks)
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 02-03-2012, 01:28 PM   #14
LittleMT
user bann'd
LittleMT's Avatar
Drives: Chevy SS
I use 15w-50 Mobil 1 per Andy at ADM on my Whipple powered Chantilly Lace.....
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6.
LittleMT is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
How to see if oil is in intake manifold? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 53 03-23-2011 06:06 PM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
