07-25-2011, 01:43 PM | #1 |
Drives: 2010 IBM 2 LT RS Join Date: Mar 2008
Some questions about the PC
When useing the PC is it ok to use fine polish and MSW on the glass ?
So from what I understand we should be waxing the paint every 3 months or so give or take a few weeks, should we be useing the fine machine polish each time? Or will we be burning are clear up ? Thanks the help Pappi |
07-25-2011, 01:48 PM | #2 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
Dylan or Junkman can better answer this question, but the question would be why as to the MSW and the PC on the glass? Waterspots?
07-25-2011, 01:50 PM | #3 |
knows 2 facts about ducks
the FMP is a very tame polish, you won't cut through the clear coat using it. But again, these are questions for Dylan and/or the Junkman
07-25-2011, 02:11 PM | #4 | |
Voice Of The Voiceless
Why do you want to use the PC on the glass? FMP can be used without burning up the clear, but just waxing the car would suffice.
07-25-2011, 03:09 PM | #5 | |
Drives: The shiny ones. Join Date: Mar 2010
Like the others suggested, you can use polish on glass to remove stubborn water spots, but FMP being so mild it might not get the job done. Personally I prefer Swirl & Haze Remover on the orange pad for water spot removal. I'd skip the MSW (now called Machine Super SEALANT) on the glass... doesn't really bond well there so you'd likely be wasting effort. On the paint you'll only polish as needed and don't concern yourself with setting a timetable for applying more sealant. Evaluate the car when you wash... if the water beads and the finish looks good then no more is needed. If after a wash and rinse the water is going flat or 'sticking' to the paint then its time to add a fresh coat of sealant. |
07-25-2011, 03:23 PM | #6 |
Thanks all.... this is a great place to get answers and so dang fast to.
pappi |
07-25-2011, 04:28 PM | #7 |
Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
To be honest if you have water spots, wash the car.
I had a serious case of water spots that I got from work due to the sprinklers and the Texas heat. Car sat out and spots developed. Prompted me to buy a pc and all the goodies. I set off to use the PC and part of the process was a two bucket was along with my foam gun. Once I have finished the wash, foam, rinse and dry the spots were gone. I continued on with the PC since I started out to do it. Bottom line is you may only need to wash the car in the shade to remove the spots. Cheers K |
07-25-2011, 04:40 PM | #8 | |
[B]
Similar Threads | ||||
Detailing questions answered here! | Moose | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 636 | 06-04-2011 12:27 PM |
Couple of questions | codo | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 09-29-2009 08:51 PM |
ordering questions...how long, when should i order... etc | haleyd | Camaro Price | Ordering | Tracking | Dealers Discussions | 10 | 07-25-2009 01:47 PM |
so many questions about the new camaro... | haleyd | Camaro Price | Ordering | Tracking | Dealers Discussions | 14 | 07-22-2009 02:23 PM |
New member with a few questions | rachelcb80 | 5th Gen Camaro SS LS LT General Discussions | 21 | 06-29-2009 11:02 AM |
