Old 07-26-2011, 07:44 PM   #1
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Amp install in battery/spare tire area?
I'm looking for a place to install my amp (JL HD 900/5). I want to keep it hidden and the stock location looks a little too tight for fitting all the wiring. I was thinking about installing the amp in front of the battery. See my picture below to get an idea what I mean. Any reasons this wouldn't work?
The two things I can see being a concern are air flow and electromagnetic interference with the battery and cables near the amp.
The compartment is fairly large so I'm thinking I should be OK with air flow and if I have noise problems I can get some EMI tape to cover the wires.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 07-26-2011, 07:50 PM   #2
iMONEY
iMONEY's Avatar
Drives: RS 2011
will it slide around or is it held down?
iMONEY is offline   Reply With Quote
Old 07-26-2011, 07:54 PM   #3
Agent WD-40
My plan is to make a mount for it so it doesn't move. I was just showing how I'm going to position it.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 07-26-2011, 07:55 PM   #4
Wantconvertible
Wantconvertible's Avatar
Drives: 2011 SS/RS VERT
Velgro it down
Wantconvertible is offline   Reply With Quote
Old 07-26-2011, 07:56 PM   #5
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
I tried this once. You'll find out quickly that it will shut down from lack of airflow. It doesn't matter that you have space, the air in that confined space will heat up quickly.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 07-26-2011, 08:13 PM   #6
Agent WD-40
What kind of amp was it you tried this with?
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 07-26-2011, 08:18 PM   #7
Camarowguy
Camarowguy's Avatar
A bazooka, an mtx, a Sony and a dual. Try it if you don't believe me. It may get away with it running a light load, like highs....but if your running bass and the amp gets warm...it will shut down. Maybe not right away, but eventually. And on a hot summer day, it'll be worse. Btw, I professionally installed car audio for over a decade and I'm mecp certified. So I'm saying this from lots of experience.
Old 07-26-2011, 08:21 PM   #8
iMONEY
iMONEY's Avatar
Drives: RS 2011
I dont know. Looks cool for being hidden.\ Just not sure about how hot it will get. Jl tend to stay cool but confined like that. not sure.
Old 07-26-2011, 08:24 PM   #9
Camarowguy
Camarowguy's Avatar
Well try it and see
Old 07-26-2011, 09:55 PM   #10
toyboy1980
toyboy1980's Avatar
Drives: 2012 45th 2LT/RS
Just put my amp in that exact space today. Add me to the "try it and see" list. So far so good. It was 101° here today.
Mods: RX Catch Can / MRT Version 2.0 Exhaust / RotoFab CAI / Apex Motorsports Scoop + Windshield Washer Bottle Relocation / Hurst "HardDrive" Plate / Mud Guards / Heritage Grill + Street Scene Lower Valance / Metra Kit + Pioneer AVIC Z120BT / AAC "Ghosted" LED Concept Side Markers / P13W Plasma LED Bulbs + DRL Harness
toyboy1980 is offline   Reply With Quote
Old 07-26-2011, 11:03 PM   #11
black.
Drives: IBM 2SS
it definitely will get hot I burned up a sony xplod amp one time with lack out air and the only reason I found out is when I was looking in the back seat of my car for a cd and smoke was coming out behind the seat.
black. is offline   Reply With Quote
Old 07-27-2011, 07:32 AM   #12
tbone587
Drives: 2011 Camaro
I dont think you will have any issues with that HD amp. I can see other brand amps that are not class d shutting down, but those amps running pretty cool.
tbone587 is offline   Reply With Quote
Old 07-27-2011, 08:07 AM   #13
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
I know the battery has a vent tube but if it leaks hydrogen gas into the unvented space and you add a heat generating device. You do the math.
MMC is offline   Reply With Quote
Old 07-27-2011, 08:56 AM   #14
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Had mine there for awhile, wasn't comfortable with the lack of air flow, went with the ******** passenger side mount.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Amp install? CJM1682 Camaro DIY & HOW-TO instructions & discussions 0 08-08-2010 03:14 PM
Spring Install in Orlando Area? racer50200 USA - Southeast 9 11-01-2009 08:28 AM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 12:25 PM
