Old 07-30-2011, 01:29 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
BMR END LINK FAILURE
Hello, had a BMR End Link Kit For Sway Bars, Front failure today, at first I thought the bolt came loose that cause this after spending 60 dollors at a auto part store since I was stuck on the side of the road and finally getting it taken off the bolt on the end link broke. it almost took out my ABS line and cause my chrome rim to get sractched really bad... I am going to contact BMR on Monday about this just wanted to share what happen.. Hofully BMR chimes in on this and does the right thing by me on this issue. its really upsetting to say the least... I am lucky it did not cause more damage or me to get into an accident.. this is a daily driver too with 1 day of auto crossing.. I do not get it...
MARINE1991 is offline   Reply With Quote
Old 07-30-2011, 01:38 PM   #2
Merc
In The Circle
Merc's Avatar
Holly Shit that suck's. I have the same end links. Subcribed!
Old 07-30-2011, 01:41 PM   #3
Merc
In The Circle
Merc's Avatar
That came from normal street driving? I've tracked Pumpkin several times and drove the bag off it with no issues.
Old 07-30-2011, 01:42 PM   #4
MARINE1991
MARINE1991's Avatar
Yea I know it might just be my luck to get a bad part or somthing.. Have to see what BMR says about it on Monday...
Old 07-30-2011, 01:45 PM   #5
IROCanSS
Drives: 89 IROC 350
My guess is unlucky and a bad part. BMR is top notch and I have been running their parts since I got my car. I have the end links and so far so good...
I'll keep watch on this though. I still can not tell from the picks what happened. Did the bolt break and the endlink got caught up in the wheel and thats what bent it?
Old 07-30-2011, 01:46 PM   #6
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Where is the other end of the hyme joint? Was it still on the upper end link mount?
Squintz Palladoris is offline   Reply With Quote
Old 07-30-2011, 01:49 PM   #7
MARINE1991
MARINE1991's Avatar
Yes its still bolted to the strut, I just took off the lower one to get the part out.
Yes that is exactly what happened. the bolt just seemed to break today while driving..
Old 07-30-2011, 01:51 PM   #8
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
dayum...that looks crazy, but I am glad u are alive to talk of it...this could of really been worst. I hope BMR treats u right. I have faith they will.
ipimpthisc is offline   Reply With Quote
Old 07-30-2011, 01:53 PM   #9
MARINE1991
MARINE1991's Avatar
I do too, just pissed and I have all there stuff and its been good so far..
Old 07-30-2011, 01:56 PM   #10
Merc
In The Circle
Merc's Avatar
K, now I get it. I was wondering how you bent the rod. I know BMR changed suppliers for the hymes in the early going. I'll be all over BMR on Monday to know why. Be some pissed if it happened to me. Pumpkin has every BMR part they offer to date for the Camaro, except LCA's which they claim will not work with my 17" Bogarts.
Old 07-30-2011, 02:01 PM   #11
MARINE1991
MARINE1991's Avatar
Originally Posted by Mercuryman View Post
K, now I get it. I was wondering how you bent the rod. I know BMR changed suppliers for the hymes in the early going. I'll be all over BMR on Monday to know why. Be some pissed if it happened to me. Pumpkin has every BMR part the offer to date for the Camaro, except LCA's which they claim will not work with my 17" Bogarts.
I have amost all there stuff too, even the lower control arms.. I am so pissed about his thow...
Old 07-30-2011, 02:07 PM   #12
IROCanSS
Drives: 89 IROC 350
Don't get overly pissed, shit happens and parts fail. Its the service after the imcident that will tell... I am betting they take care of you. They have always been up-standing with my concerns. I have a good bit of their stuff too and really like it.
Old 07-30-2011, 02:11 PM   #13
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Sorry to hear what happened to your car. Glad your OK. Did you check the rear end links to see how they are holding up? Cause I just bought a pair of the rear ones.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 07-30-2011, 02:12 PM   #14
MARINE1991
MARINE1991's Avatar
Yea I calming down now... I am sure they will, just venting now and wanted to share and have people check theres, not sure if you can tell if this will happen to you, but just wanted to pass it along..
FS BMR End Links & IPS SS Brake Line LS3*LLY Suspension / Chassis / Brakes 7 07-14-2011 10:53 AM
JRE 3.73 rear end w/ posi installed.....questions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-17-2011 08:04 PM
BMR rear sway bar simple installation gearhead440 Suspension / Brakes / Chassis 7 01-20-2011 09:51 AM
Pfadt Drop springs, Swaybars and adjustable end link installed! baranowski Suspension / Brakes / Chassis 1 09-07-2010 12:44 AM
XTREME BMR suspension packages start at $495.95 NOW!!!! here at Xtreme X-treme Horsepower Suspension / Chassis / Brakes 8 04-05-2010 12:19 PM
