Old 07-31-2011, 12:01 AM   #1
ya boy willz
ya boy willz's Avatar
Drives: 2011 IOM LS, 2011 CGM LS
Rotors/Brake Set up on 4th gens?
Well to begin my 4th gen is in desperate need of a brake upgrade/change. And boy do I mean desperate
It currently has some generic no name brand Pads and rotors grabbed off of some parts store that are worn down ALOT. I'm looking for a nice combination that will give me some good stopping power, not dust up a lot, and not break my bank.
I'm pretty set already on the pads. Going to be running Hawk HPS pads up front and Power Stop Evolution Ceramic brakes in the rear. The 4th gen is a daily driver and doesn't see any track action at all, just some spirited driving every once in a while so I don't need anything too overboard and no 6 piston Brembo conversions or anything .
Now the question comes down to what rotors should I run? I've been searching for like 3 days and looking at reviews and pretty much it's just a bunch of different opinions on whether slotted/cross drilled are necessary and how they're useless and blah blah.
So I want to know what some of you guys are running and what you think of my four possible set ups.
Set up 1. $480ish
Power Slot Black E-coated Slotted rotors up front w/ Hawk HPS pads
EBC UPR Premium replacement rotors in the back w/ Power Stop Evo pads
Set up 2. $350ish
Rotorworks Slotted rotors all around w/ Hawk HPS pads in the front & Power Stop Evo pads in the rear
Set up 3. $435ish
Brembo Slotted rotors up front w/ Hawk HPS Pads
EBC UPS Premium replacement rotors in the back w/ Power Stop EVO pad
Set up 4. $360ish
EBC UPS Premium replacement rotors all around w/ Hawk HPS up front & Power Stop Evo in the rear
The way I see it the rear doesn't need a big budget set up since it hardly does any braking. Also I don't want to run slotted & cross drilled because of the possibility of it cracking. Any suggestions/feed back is greatly appreciated and as a reminder this is a 3.8L V6 4th gen not the LS1 version.
2011 IOM LS - Drag DR 19s 18x7.5, Projector/Halo Fogs, Blacked out Gills, Red Calipers, Factory Spoiler, 15% Tint
2011 CGM LS- Injen CAI, Vmax Ported TB, Vmax Black Ice O'Lator, Carbon Fiber Bowties, Carbon Fiber Gills, Factory Spoiler, Stock SS Exhaust w/ Magnaflow x-pipe welded in & stock muffler delete, Miro 112 18x8.5 +35
ya boy willz is offline   Reply With Quote
Old 07-31-2011, 02:41 PM   #2
ya boy willz
Well I guess 4th gen owners drive their car around without brakes
Went ahead and ordered the Rotorworks Slotted Rotors all around along with Hawk HPS pads all around. Total price was $343 shipped to my door
I'm hoping they arrive around thursday/friday and then I'll install them and let you guys know my first impressions and later on how they turned out for me. I've heard only good things about the Rotorworks rotors on LS1tech.com and already have experience with the Hawk HPS pads so I'm thinking this is going to be a great and very affordable brake set up.
Old 07-31-2011, 03:51 PM   #3
Evil35th
Drives: 02 35th Aniversary SS/'11 RJT 2SS
Where did you order from?
02 35TH LE#3089 and 2011 2SS/RS
Evil35th is offline   Reply With Quote
Old 07-31-2011, 10:26 PM   #4
ya boy willz
The ws6store.com
I still have the links bookmarked so I posted them for you
rotors
pads
Old 07-31-2011, 10:38 PM   #5
Evil35th
Sweet, thanks!
Old 08-01-2011, 10:34 AM   #6
km9v
Drives: 2011 Camaro SS/RS M6
When I had my 4th gen, the last time I replaced rotors & pads I used AZ Duralast. Worked great.
km9v is offline   Reply With Quote
Old 08-01-2011, 02:28 PM   #7
ya boy willz
Thanks for the suggestion, I'll keep it in mind the next time a brake change comes around.
For those of you who have done the rear pads on the 4th gen, are you able to push the piston back in the caliper by simply using a c-clamp, or am I going to need to buy one of those fancy tools that goes inside the piston in order to spin it back in?
Old 08-01-2011, 08:49 PM   #8
mulehead7
stubborn as a ...
mulehead7's Avatar
Drives: '94 Trans Am
I was able to get the pistons to go back easily enough but I couldn't get the caliper back over the new rotors with both new pads installed. The Hawk HPS pads fit fine on the front with new rotor. I used PBR ultimate ceramic pads on the back. Stopping power is 100% better. Hope everything goes well with your install. Make sure you use the pad grease supplied.
mulehead7 is offline   Reply With Quote
Old 08-01-2011, 09:16 PM   #9
ya boy willz
Hmmm, we'll see how it goes when I install them then. Thanks for the heads up and for the response.
Old 08-02-2011, 01:34 AM   #10
JJ#48Racing
Drives: 1998 Camaro SS
I have HPS pads and Power Slot rotors all around. They provide good braking with very little dusting. They will start to fade after a few laps at a road course, but are great for the street.
JJ#48Racing is offline   Reply With Quote
Old 08-03-2011, 09:40 AM   #11
ya boy willz
Good to hear. All I really need is a good street set up, the camaro never sees the track.
Old 08-05-2011, 02:58 PM   #12
ya boy willz
Stuff came in. I'll be installing it sometime this weekend.
Old 08-05-2011, 07:20 PM   #13
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
That's the setup I'm planning on next. I have all EBC products on the car, and it works well but makes a lot of noise for a street setup.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 08-08-2011, 10:08 PM   #14
ya boy willz
So far I would most definitely recommend it. I installed the front Rotors/pads on Saturday and then finished up the Rear Rotors/pads on Sunday (had a car meet in between so couldn't finish it in one day). Installation was pretty easy besides a few bolts and the rear right rotor being a PITA to take off because of rust.
I sensed a definite improvement in braking power (but then again my old rotors were .10mm under minimum thickness ). I now hardly have to press down on the brakes for the car to start stopping and the car does 45-0 like it's nothing. So far from driving around with the radio off I haven't heard any of the infamous "swooshing" noise that slotted rotors make. I'm happy with the purchase and think that for the price I paid, I definitely got a sweet set up for the street.
On another note what EBC pads are you running? I've been thinking of picking up some EBC Red Stuff 3000 pads for my moms MB SLK 230 and I don't think she'd be very happy with a lot of noise/dusting.
4th Gen Stereo Kit Fraxum 4th Gen Marketplace 4 01-25-2011 09:45 PM
FS: Innovators West 8 rib pulley set jrpxxii V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 08-09-2010 08:46 PM
A question about Stripes? Blue Maro Demon 5th Gen Camaro SS LS LT General Discussions 11 07-13-2009 02:24 PM
