Old 07-31-2011, 08:33 AM   #1
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Who has LSX-427 Heads
Looking for LSX-427 heads for reasonable prices.
Found these
GMPP LS7 heads: $1043 (bare)
http://www.superchevyperformance.com...p/12578450.htm
MAST Motorsports: $1400 (bare)
http://www.mastmotorsports.com/2010/... - Bare&id=359 (Not sure what's the benefit for an extra $400)
All Pro -2 (I'm expecting these will be too expensive.)
http://www.proheads.com/products.html
I'm thinking the most realiable are probably the GMPP parts, 2nd. I like the MAST but can't justify the extra $800 p/pair. All Pro seem to have the best flow numbers at over 400 CFM, but not sure if their over-price will be worth it.
I'm planning a forged 427 LSX build, might use existing heads but thinking might be a better idea to use the machining expense to simply purchase the LS7 6 bolt heads now rather than making that change in the future. My goal is to get about 700-800rwhp. with ProCharger installed using anywhere from 12-16psi. of boost.
calbert1999 is offline   Reply With Quote
Old 07-31-2011, 02:15 PM   #2
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
I think ive heard more than a few say they arent worth it..but i do believe there is a person on here who has..just cant remember which thread i saw him post in.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 07-31-2011, 03:06 PM   #3
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Found these
http://www.mastmotorsports.com/2010/product-view.php?cat=Cylinder Heads - Bare&id=359 (Not sure what's the benefit for an extra $400)
I thought, according to your old sig, that you had over 700 hp on 8 or 9 psi already....?
HufferSS is offline   Reply With Quote
Old 07-31-2011, 10:53 PM   #4
calbert1999
Camaro SS Lover
Let me know if you recall who. In my case with a new LSX 427ci. forged engien it may be more feasible to purchase LS7 heads than to machine the existing heads to all new parts on a new block. Probably not much to gain on an LS3 to simply purchase new heads to get minimal HP gains, but on a new engine and lots of boost definately worth it.
Yup that's right and that was just the tip of the iceberg, had to dial everything down as much as possible and still made 680rwhp.
Now forging and stroking to a 427ci. had planned to do it over the winter, but LS3 internals couldn't hold the power so doing next project much earlier than I had planned.
Old 08-06-2011, 03:32 PM   #5
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Ok...but if you had 700 on 8 psi...why would you need to run 12 - 16 with a 427 to get the same power.....?
Old 08-06-2011, 04:42 PM   #6
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
All Pro's are the real deal I run them on my car, they do make more power than ported LS7 heads
CC Performance is offline   Reply With Quote
Old 08-06-2011, 05:22 PM   #7
calbert1999
Camaro SS Lover
Compression will not be the same we'll use 9.1:1 on the LSX (LS3 is 10.7:1). We'll use more boost to compensate. Most likely will end up with approx. 800rwhp. or more. The difference is the LSX427 will be built from the ground up to handle boost (without concerns of breaking), the LS3 is not.
Also, TQ at low RPM will be through the roof this is another advantage of higher displacement, less compression, on higher boost, and forged internals.
Yeah. I really like the All Pro heads, but they're very pricey compared to the GM heads and most likely more than what I need.
Anyone have an LSX 427? jrpxxii V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 08-10-2010 07:36 PM
Kyle Gilmours 427 lsx pro charged!! X-treme Horsepower Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 91 07-20-2010 10:36 PM
427 KILLER74Z28 General Automotive + Other Cars Discussion 5 06-17-2010 11:55 PM
