Will axle back exhaust fix common exhaust rattle?
OK ill try to make a long story short. I have new axle back exhaust arriving on Wednesday. Today on the way into work I heard a rattle in the exhaust. Reading old post here I have realized I believe that it is a loose baffle in the exhaust system. Everyone else has described the noise i'm getting in mine to a T.
The question is will replacing the axle back solve this issue or is it in more than just the muffler. Should I have GM replace the exhaust system before I make any mods (I am still under warranty) or will I be fine once I eliminate the mufflers? Please advise |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '10 SS CGM #75,288, '14 Stingray Join Date: Aug 2009
I developed the exact problem you stated. Started at about 15,000 miles. Resonation sounding noise - annoying as hell.
Anyway, I purchased a Borla S-Type Axle Back Exhaust and "poof be gone" - no more rattle, vibration, resonation - just a beastly growl - the way a V8 should sound. Good luck. |
![]() ![]() Drives: 2010 2ss/rs M6 Join Date: Nov 2010
If the exhaust is hitting the tunnel brace it will probably still be there with the new exhaust. I put some thick washers in between the brace and the car and the noise is gone.
| V8 Camaro Aftermarket Exhaust Video Clips Compilation | tjbusa | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 591 | 07-06-2022 08:38 AM |
| Will axle back exhaust fix common exhaust rattle? | Jagerday | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 08-02-2011 05:44 AM |
| FS: Borla axle back exhaust | stubby | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 3 | 11-29-2010 07:29 PM |
| FS GMPP LS3, L99 Axle Back Exhaust $375 Shipped | Saving41 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 6 | 08-25-2010 05:25 PM |
| EXHAUST | Milk 1027 | Wiki | 2 | 03-07-2010 09:20 PM |
