Old 08-02-2011, 03:16 AM   #1
v6
v6's Avatar
Drives: 2012 45th 2LT RS
Too tall for the camaro...
I have been saving up for a camaro since the 2010's came out. I've decided to get a 2lt manual. So today i went to test drive one, and i don't fit. WTF!! I'm 6'3". Isn't this like a normal height for most guys who are middle aged? This totally ruined my day and my dreams. My head is touching the ceiling and i have to duck my head down to see anything... I have to bend my knees dramatically to push the damn clutch in. Are any of you camaro owners my same height?
Also, is there any such thing as being able to mod the seat to make it go back further?
Seriously, you would think a car company would design a car with everyone in mind.
v6 is offline   Reply With Quote
Old 08-02-2011, 03:19 AM   #2
ZachSGMSS
ZachSGMSS's Avatar
Drives: 2011 2SS/RS SGM Camaro
Did you lower the seat and have it back all the way? I know theres some pretty tall guys on here that drive their cars without any problems. Hopefully one of them will come in and tell you what they do.
ZachSGMSS is offline   Reply With Quote
Old 08-02-2011, 03:21 AM   #3
v6
v6's Avatar
It was all the way back i checked. But could it be that the seat doesnt move all the way somehow when the car isnt on or keys arent in?
Old 08-02-2011, 03:27 AM   #4
BMTGIE
BMTGIE's Avatar
Drives: 2014 RRM SS/ 2011 Black LS
Did you pump the lever to make the seat go all the way down ?
BMTGIE is offline   Reply With Quote
Old 08-02-2011, 03:32 AM   #5
v6
v6's Avatar
i didn't see a lever. On the side of the seat there were two levers for slide back and recline, but i didn't notice one to make it go down. is it in the front??
Old 08-02-2011, 03:37 AM   #6
ZachSGMSS
ZachSGMSS's Avatar
I think as long as the keys are in the seat will move all the way. I don't see why it wouldn't anyway. I'm pretty sure I've seen someone on here thats the same height as you say they fit in their car with the seat all the way back and down. So again.. Hopefully one of them will come in and tell you what they do. That's all the help I can really give. Good luck. Hope you can find a way to fit in the car you want.
If I remember correctly the same switch that moves it forward and back also goes up and down.
Old 08-02-2011, 03:38 AM   #7
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
IIRC (I haven't seen/driven the car in a month :( )the "up and down" on my 1SS is electric, and on the side of the seat. Should be the same on the 2lt.
I'm 6'2" AND have the sunroof, so I loose some more head room, but I still manage to drive the car comfortably... Although it does take me a while to get the seat set right again if someone moves it, like if I take it to the dealer for service... But once it's right, its usually good. The only problem I have is wearing a helmet when I go to the drag strip, then I have to tilt my head to the side, most likely because of the sunroof.
Jason@JacFab is offline   Reply With Quote
Old 08-02-2011, 03:39 AM   #8
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
You have to push the button down and then the seat should go down. I'm 6' 2" and I have no problems..
Tyler360 is offline   Reply With Quote
Old 08-02-2011, 03:40 AM   #9
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I'm 6'4" with no sun roof, and I don't have any problems.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 08-02-2011, 03:40 AM   #10
v6
v6's Avatar
Originally Posted by RacnJsn95 View Post
IIRC the "up and down" on my 1SS is electric, and on the side of the seat. Should be the same on the 2lt.
So you can only move the seat up and down with the 2lt or 2ss?? Okay cool. that was probably my problem. I was sitting in a 1lt.
Old 08-02-2011, 03:44 AM   #11
Jason@JacFab
I don't know about that... From reading an above post there is a pump/jack lever that moves the seat up and down on the LS? (much like a VW Jetta or something)...I don't know if the 1LT has the jack lever, or is electric also... Gotta research it.
Old 08-02-2011, 03:51 AM   #12
BMTGIE
BMTGIE's Avatar
Just went to go take a quick pic
Old 08-02-2011, 04:07 AM   #13
Oliv59
Oliv59's Avatar
Drives: 45th M6
Hi guy,
Like you, I plan buying a Camaro.
But I'm 6"7, and I was worried about that.
Fortunately, I was able to try enter a 1ss Camaro and ... that's fine, with the seat all ways back and down.
Not a lot of space available between my head and roof, but that's ok.
In this video (2mn37s), you'll see Lebron James (6"8) and his Camaro
Keep the faith !
Oliv59
Oliv59 is offline   Reply With Quote
Old 08-02-2011, 06:54 AM   #14
Motleigh
Motleigh's Avatar
Drives: 2011 Camaro RS Silver Ice
I'm 6' tall and have no problems once I'm in the car. I have to get in the car like I'm wearing a miniskirt and no panties- sit down on the seat with both feet on the ground, then pivot into the car- but once I'm in, its all good. I do have to play with the seat to get it just right every time I drive it, because my hubby drives it more and he's 2" shorter with legs that are 4" shorter.
All women know how to fly...if you take our angel wings away, we'll find a broomstick
Motleigh is offline   Reply With Quote
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 04-23-2024 12:22 PM
