"To Punish And Enslave"
Drives: B E RS GBA #72541 3564 CC 220 CI Join Date: May 2011
can someone help (voltage problum)
so i have my first major problum with my camaro
i could use some help or insight i am going to call my dealer but...the voltage on my camaro is droping badly i believe when i look at my DIC "normal" is something like 14.2 volts but i noticed it when i used my radar it shut off in a safe mode cause the volts was too look looked yep 12.2 and i was driveing home and with out the radar on and only the music playing (daylight out so daylight lights on) it was hovering around 12.5 .4ish ![]() wtf is going worng with my camaro i had auto zone do a test on it and it said bad battery but he was doing it upfront not from the battery in the trunk its self ugh WTF! ![]() ![]()
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession 90% canadian 10% mexican 100% american muscle :flag2: |
Tampa Bay Camaros
Drives: 2010 Camaro 1SS/RS Inferno Orange Join Date: Sep 2010
Did you have the alt. tested?
yes there it was runing fine no warnings only said the battery was bad but he said sence it was upfront not from the battery its self it could be faulty IS there something worng if the volts drop so low?
Tampa Bay Camaros
Mine stays at 13.5 all the time.
yours is a v8 though lol differnt engain just saying
#6 |
![]() Drives: aqua blue ls and inferno orange ss Join Date: Feb 2010
I had a similar question. I noticed the same thing and contacted the dealer. They said it's normal. I watched the voltage drop to 12.2 then it comes back up to 14.8, then back down, then back up. It's the way the voltage regulator works in these cars. My wifes LS and My SS as well as my Traverse all do the exact same thing. Turn the DIC to the voltage reading then drive the car and see if it goes back up and so forth. If it does then you have nothing to worry about. Now if it stays at 12.2 then you need to get it checked out.
#7 |
Tampa Bay Camaros
The voltage reg. is in the alternator. If it fluctuates that much then there is a problem with the alt.
#8 | |
#9 | |
#10 |
Tampa Bay Camaros
the dealer needs to replace the alt. When the batt. volts drop below 13 vdc then the reg. turns the alt. on to keep the volts above 13 while running.
Your reg. isnt kicking on when it is supposed to. |
#11 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
I'm thinking a loose negative. Check terminals at the battery. Its a 12 volt system, so in the 12 and up is all ok. Fluctuating like that sounds like a loose terminal
#12 | |
#13 | |
anybody want to help i will pay you 5 bucks
#14 |
Tampa Bay Camaros
A loose terminal is going to give you a low volt. reading at the battery and a high reading at the alt.
I am a certified mech. fellas. |
| How to Wire Footwell Lighting | TonyNo | Camaro DIY & HOW-TO instructions & discussions | 804 | 09-05-2021 08:13 AM |
| Low battery voltage | Chevyman11 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 8 | 04-26-2011 12:16 PM |
| Battery Voltage Changing | mpiper | 5th Gen Camaro SS LS LT General Discussions | 2 | 02-18-2011 07:47 AM |
| Voltage Guage | macwest | Camaro ZL1 Forum - ZL1 Specific Topics | 15 | 02-13-2011 07:00 PM |
| Lingenfelter 2010-2011 Camaro fuel pump voltage booster kit | jrh@lpe | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 08-28-2010 12:24 PM |
