Old 08-02-2011, 06:09 PM   #1
SSKyle
Drives: 2011 SS/RS
Max duration/lift before PTV issues?
How much duration and lift is tolerable before having PTV problems?
Last edited by SSKyle; 08-02-2011 at 06:10 PM. Reason: With stock set-up (heads and pistons)
SSKyle is offline   Reply With Quote
Old 08-02-2011, 10:29 PM   #2
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
member mossman had a 231/243 lsa 115 and he had no issues...good question though..maybe more members will chime in.
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 08-02-2011, 10:33 PM   #3
Parapdrapa
Drives: 2010 Camaro
There are many combinations of the 2
Parapdrapa is offline   Reply With Quote
Old 08-02-2011, 10:53 PM   #4
Patrick G
Drives: 2009 Pontiac G8 GT
On the intake, you can run a 230-231 lobe at a 112 intake centerline (with lift around .600") and maintain .080" P to V clearance. For every degree you advance the ICL or every 2 degrees of additional duration you add, you lose .006" (six thousandths) of P to V clearance.
So if you had a 235 lobe on a 112 ICL, you would have around .068" P to V clearance. A 235 lobe on a 110 ICL would have .055" P to V. Some people have no idea how tight they're running their P to V clearance with cams above 230 in duration on the intake side.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Old 08-02-2011, 11:13 PM   #5
camarohead
camarohead's Avatar
great info...yea i definetly wanted to stay safe on this issue..went with the 226/234 lsa 113..been researching alot and think this will fit my goals..
Old 08-02-2011, 11:17 PM   #6
MasterZ
MasterZ's Avatar
Drives: 2010 Camaro SS/RS
running 228 dur. with .660 lift on a 112+2 without any issues on the intake side.
MasterZ is offline   Reply With Quote
Numerous issues with my 2011 SS Runin11z Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 07-29-2011 05:02 PM
Hotchkis 4-Point Chassis Max Front Strut Brace AJ@ECSMotorsports Suspension / Chassis / Brakes 57 11-13-2010 04:29 PM
LMPerformance, Hotchkis 2010 Camaro Chassis Max Brace LMPerformance V8 Bolt-Ons & Tunes 0 01-05-2010 12:17 PM
ISSUES with YOUR CAMARO! JewelZ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 65 10-03-2009 02:45 PM
Issues With My Camaro - We Need a Forum Here Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 14 06-15-2009 02:04 PM
