![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 69 Camaro, 02 Escalade, 67 Eleanor Join Date: Nov 2009
2010+ Camaro V6/V8 Roto-Fab Washer Reservoir Relocation Kit & ADM Performance Scoop!
ADM Performance Cold Air Scoop & Roto-Fab Washer Reservoir Relocation Kit Brand Name Components You Can Trust. Installation of the ADM Cold Air Scoop requires the removal of the factory washer bottle. Roto-Fab's Washer Reservoir Relocation Kit is the perfect solution. You can now add more and cooler air to your intake without sacrifice. Take advantage of this money saving package plus free shipping. This package will work on any intake system that has an open bottom for the ADM Scoop to force air into. ADM Performance Cold Air Scoop Finally a solution to bring more air to your Cold Air Intake. Scoop (only) for converting the ADM Performance Street Cold Air intake to the Highflow Race Cold Air Intake. The air scoop for the ADM Performance Highflow Race Cold Air Intake works great with intakes from other manufacturers too. (Intake must have an open bottom to benefit) Installation is simple and does not even require you to take off the front fascia. Installation Instructions Roto-Fab Washer Reservoir Relocation Kit This is a complete relocation kit including all hardware, hoses, in-line filter, remote pump mounting bracket and detailed instructions. The reservoir is custom molded to fit your Camaro perfectly. For mounting, it utilizes the vacant stud along with an unused hole lower on the body. The tank has molded-in threads for the supplied internally vented cap as well as a molded-in brass insert for the outlet fitting to engage. We supply a rubber cushion mounting bracket with a stainless steel bolt which mounts the factory pump to one of threaded holes previously used to mount the stock reservoir. This location allows use of the original wiring without lengthening or modifying. The instructions assume you are installing an ADM scoop or other air entry during the installation. $189.99 Shipped! ![]() Order Now: http://autoagenda.com/2010-camaro-v6...-kit-adm-scoop |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Is there any deal on just the washer reservoir relocation kit?
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
The ADM Performance Scoop and Roto-Fab Reservoir Relocation kit work well with each other and ship nicely together. We can't offer any deals on just the reservoir relocation kit right now, but will keep you posted.
![]() Drives: 2011 SS Camaro Join Date: Jun 2011
Does this actually belong in this forum???
#6 |
![]() Drives: 2010 2SS Inferno Orange L99 Join Date: Jun 2011
whats the price for both shipped to 75087
| Tags |
| auto agenda |
| Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 10:27 PM |
| A lot of complaints that the Camaro seems very large. | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 70 | 03-01-2011 02:10 AM |
| 4th Annual GM Performance Parts LSX Shootout!! | nmcajeff | Dragstrip and Launch Techniques Discussion | 3 | 07-30-2010 01:05 PM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 09:48 PM |
