![]() Drives: Black 2SS Join Date: Feb 2010
Getting these lowered bad boys off the ground
Does anyone have a recommendation for a good, low profile jack for lifting your Camaro off the ground?
My Camaro is lowered 1.5 inches below stock ride height and I have an elaborate process to get my jack under the car. I have to drive up onto 2x6s to get enough clearance to get my jack under the car. I'm wondering if anyone has found a good, low profile jack that can fit under a lowered car. It would be a bonus if it was light enough to take to track events without breaking your back. Thanks in advance. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM SS/RS COTW 7/5/2010 Join Date: Oct 2008
im gonna catch some flack but i use a harbor freight low pro one haha. this one
http://www.harborfreight.com/automot...html-7814.html |
#3 | |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
![]() Drives: 2010 CGM 2SS/RS Join Date: Feb 2011
I have encountered the same situation recently when I installed my Heritage Grille.
Here's one from Northern Tools: ![]() http://www.northerntool.com/shop/too...5429_200345429 It's got a 3 1/2" minimum lift, which shouldn't be a problem getting under the frame rail. My only concern is the length of the arm to get to the frame rail. However, Omega makes one with a longer arm (I think I'm gonna end up getting this one: ![]() this one has a minimum lift height of 2 1/2", but is a little more expensive. I was hoping to find an aluminum one,,,but they're all too small in terms of the lifting arm length to get under the car. hope this helps Allen
'69 SS Camaro 2SS/RS, CGM, Magnaflow Exhaust, Pfadt Suspension, Airaid intake (Sold) 71 RS Camaro (Sold) Z Car (Sorry, Nissan 350Z) |
Drives: 89 IROC 350 Join Date: Mar 2009
I got a craftsman low profile. Works great and has dual piston so it goes up super fast until it feels resistance then goes slow.
No clearance issues unless I do something dumb... which yes, believe it or not, HAS happened!
#6 |
... but my jack is crazy heavy. I also got it to lift my 3/4 ton diesel truck so taking it places is not really feasible.
#7 | |
EYE CANDY
#8 |
Thanks for all the recommendations. Looks like I'm busting out the credit card and doing some damage. Thanks again
#9 |
Supercharged LSX
What I've been doing so far is drive the car onto some 1x6 that I have cut to 2' lengths. Then I can use my 4 ton craftsman.
#10 |
One more question. For those of you using the harbor freight jack, what lift points do you use to lift your Camaro? Like jrhaus76 states, the arm looks pretty short. I'm wondering what points you use to hoist your car, given that you're happy with the product. Thanks.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
I've got the cheap craftsman 2 1/2 ton and it fits under my car (eibach springs/sways and GFX) just fine. I have to slide it in from the tire back (fronts only) but it gets the job done for cheap. (I got the jack, stands and ramps for $40 or $50.)
I use the factory lift points on each of the corners. There is a notch cut in the sheet metal where the jack should be placed.
#12 | |
#13 | |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
Same goes for any jack but double for a cheap one. |
#14 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
I use a craftsman - bought at sears. I turn the wheel all the way to lock then slide it between the tire and rocker panel. Works just fine.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
| Bad Vibe - My V6 with an attitude | hardestysa | Member Car Journals | 245 | 01-29-2016 10:16 PM |
| CGM lowered and sleek | corvettecamaro | Camaro Photos | Spyshots | Video | Media Gallery | 93 | 01-03-2011 03:51 PM |
| Ground Effects. | Bbrock25 | Camaro Photos | Spyshots | Video | Media Gallery | 3 | 06-23-2009 04:00 PM |
| News on Ground Effects? | DkknightX | 5th Gen Camaro SS LS LT General Discussions | 7 | 06-22-2009 11:10 AM |
| Ground Effects (ground clearance) | cerberus | 5th Gen Camaro SS LS LT General Discussions | 9 | 06-14-2009 05:10 PM |
