Old 08-08-2011, 08:40 PM   #1
rgaylo
Drives: Camaro LS V6
Exclamation "Service StabiliTrak" after replacing steering wheel
So I replaced the stock steering wheel on my 2011 LS with a leather wrapped one from a 2011 SS convertible, and now "Service StabiliTrack" shows up along with a couple of the traction control lights ... Does anyone know anything about this? I read through a lot of threads before buying this steering wheel so that I knew it would work...kind of odd that replacing the steering would cause it tho. Thanks for the help!
rgaylo is offline   Reply With Quote
Old 08-08-2011, 09:03 PM   #2
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
Sounds like something happened with your steering angle sensor while you replaced the wheel. Gonna take a trip to the dealer.
Ucantctchme is offline   Reply With Quote
Old 08-08-2011, 09:18 PM   #3
rgaylo
Hmm, where is the angle sensor located? When I replaced the wheel I turned the black connector plate behind it a few times. Would that cause an issue to show up?
Old 08-08-2011, 10:15 PM   #4
rgaylo
I just talked to Onstar to see if any error codes were showing up but they couldn't find anything. I talked with the Onstar technical expert about replacing the steering wheel and he mentioned something about the steering wheel yaw sensor. Ill have to pull everything apart again and check the connections. If that doesn't fix it it looks like I will be visiting the dealership ...
Old 08-11-2011, 10:12 AM   #5
rgaylo
After looking through some other threads related to the steering wheel and/or service stabilitrak message I found some more info. The steering wheel angle sensor is connected to the clockspring (the clockspring is the part which has the steering wheel buttons connector as well as the airbag wires). When I replaced the steering wheel I accidentally turned it one turn to the right before putting the steering wheel back on .
When I drove the car the sensor would measure that I was turning the wheel past the maximum and it would throw up the error. I didnt know what side I turned it to so I turned it in each direction until the error would show. I took the wheel back off and turned the clockspring in the opposite direction one turn and everything was good to go after I put it all back together.
Old 08-11-2011, 12:11 PM   #6
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
Good info. Thanks for the followup.
2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen.
2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE
John Deere Boy is offline   Reply With Quote
Old 12-20-2011, 02:07 PM   #7
wastintime
wastintime's Avatar
Drives: 2011 Camaro SS race car
When you have the wheel off an look at the clockspring, there is a clear window. You know it is aligned if the electrical connectors are in the correct 12 o'clock position and you can see a yellow roller in the window. Should be about the 5 o'clock position.
wastintime is offline   Reply With Quote
Old 12-22-2011, 02:11 AM   #8
11 Camaro IBM
Drives: Camaro IBM
Can anyone please post pics
11 Camaro IBM is offline   Reply With Quote
Old 12-22-2011, 02:19 AM   #9
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Good to know info.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 06-22-2012, 11:36 PM   #10
johnntab
johnntab's Avatar
Drives: 2010 2SSRS, 69 SS, 92 RS, 2018 ZL1
Thanks
You just saved me tons of time and well over a hundred dollars. I pulled my wheel off too aggressively doing the HUD install and apparently turned my steering angle sensor before putting it back on.
The dealer couldn't fix it till next week, and it was going to be a hassle if they reflash the computer because I have a custom tune.
You don't know just how much I appreciate this information.
Thank you x 1000.
ORDER # NDPPHT 2010 2SS/RS
ORDER # VPZJRM 2018 ZL1
johnntab is offline   Reply With Quote
Old 06-27-2012, 01:05 AM   #11
SS Drifter
Drives: 2010 2SS/RS L99
Good info, I'm swapping wheelsmthis weekend.
SS Drifter is offline   Reply With Quote
Old 06-27-2012, 04:45 AM   #12
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Anyone know the torque spec of the steering wheel bolt?
Old 06-27-2012, 05:26 PM   #13
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
I recently had the same issue. Don't take it to the dealership....they will take forever to diagnose the issue and charge the hell out of U. All you have to do is rotate the clock sensor with your finger and the stabiltrak light will go off.
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 07-19-2012, 05:52 PM   #14
Jorbob
Sorry, I think im confused. I got this service stabilitrak after ARH header install. No codes, just this service stabilitrak. In order to install the ARH headers, you need to disconnect the steering shaft that runs right along the engine bay area to get the headers off and on. So Im think I messed something doing that... Is what you guys are talking about near the engine bay, or is this something under the dash near the steering wheel itself? Or do you literally have to take off the steering wheel to get at it? Once the steering shaft was disconnected, I could freely spin the steering while inside the car from the engine bay, so I could have twisted it a few times trying to get it all back together?
Jorbob is offline   Reply With Quote
stabilitrak, steering wheel
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Ace Custom Steering - Name Your Wheel! SparksAI Interior Parts & Accessories 30 04-13-2011 04:44 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
Customize Your Steering Wheel In Any Leather & Stitching Colors (Pictures) dsvcustoms Interior Parts & Accessories 4 09-06-2010 01:50 AM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
