Old 08-09-2011, 11:06 AM   #1
xLoGiK1
xLoGiK1's Avatar
Drives: 2010 2LT/RS Camaro
Brake Pedal acting up....
Alright I need some opinions;
I was pulling my car out of the garage this morning and when I would press onto the Brake pedal it sounded like a pump. As if I was pumping air into a basketball or something and I would feel air coming onto my foot when the brake pedal was pressed.
What can this be? It's very strange.
xLoGiK1 is offline   Reply With Quote
Old 08-09-2011, 12:59 PM   #2
TooCool5
TooCool5's Avatar
I would take it to the dealer, don't take chances with your brakes.
Old 08-09-2011, 01:09 PM   #3
xLoGiK1
xLoGiK1's Avatar
Thanks, I will most likely head over there tomorrow.
Old 08-09-2011, 02:50 PM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
wonder if it was some kind of abs system test. anything unusual about the way you started and moved it?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 08-09-2011, 02:54 PM   #5
10forty2
10forty2's Avatar
Drives: 1992 Chevy K5 Blazer
Is there a rubber boot around the brake pedal at the firewall? Could be as simple as it came loose from the firewall and the ambient air inside it is now blowing on your foot and you can hear it when you depress the pedal.
Love beautiful photos? Please visit:
http://dougloganphotography.zenfolio.com
10forty2 is offline   Reply With Quote
Old 08-09-2011, 02:55 PM   #6
xLoGiK1
xLoGiK1's Avatar
The car brakes fine. I just found it rather odd that it was making such a loud noise. I definitely haven't noticed it before
Old 08-09-2011, 02:55 PM   #7
xLoGiK1
xLoGiK1's Avatar
Ah, I will check this when I get back home. You may be right. I'll report back here as soon as I take a look at it.
Thanks!
Old 08-09-2011, 03:04 PM   #8
SS>GT
SS>GT's Avatar
Drives: 2010 Camaro SS
Thanks!
Mine makes a really, really fast "ta ta ta" when im going in reverse and apply the brakes. Only does it once in a while, really weird, but braking is perfect none the less. is this something to worry about?
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black.
GO TEAM LS3
SS>GT is offline   Reply With Quote
Old 08-09-2011, 03:07 PM   #9
spencer489
spencer489's Avatar
Drives: 2013 Pre-Production SW Camaro 1le
mine dose that too when i first get in and press the brakes
spencer489 is offline   Reply With Quote
Old 08-09-2011, 04:01 PM   #10
xLoGiK1
xLoGiK1's Avatar
Nice to know I'm not alone on this one. I should be home within the hour to check on that rubber boot 10Forty2 was talking about
Old 08-09-2011, 05:47 PM   #11
FastEddie
Drives: 2010 IOM LS3 2SS/RS Camaro
I hear electric cars NEVER do that, if that helps any.
FastEddie is offline   Reply With Quote
Old 08-10-2011, 10:47 AM   #12
xLoGiK1
xLoGiK1's Avatar
I did check the pedal and there was a rubber footing the was loose, so it's all fixed now
Old 08-10-2011, 11:30 AM   #13
colemanvoice
team chicklet camaro
colemanvoice's Avatar
Drives: MOTL3Y
Mine does exactly what you describe. It only does it when I back out of my driveway...sometimes. Everything has always seemed to work okay though. Scares the hell out of me each time it does it.
I feel that if I took it in for this, it wouldn't do it while at the shop. Then I would bet my car back with a new chip in the paint, like last time.
colemanvoice is offline   Reply With Quote
Old 08-10-2011, 11:43 AM   #14
xLoGiK1
xLoGiK1's Avatar
It shouldn't be anything to worry about. Mine does the same, but yesterday I noticed it more than usual. There was a rubber piece that connects on the top of the brake pedal that was loose. You may want to check that out yourself
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 09:39 AM
Stainless Steel Brake Lines on Sale MTI Racing Kevin Suspension / Chassis / Brakes 17 12-02-2010 12:05 PM
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More maperformance Suspension / Chassis / Brakes 10 10-04-2010 02:36 PM
