Old 08-11-2011, 08:30 PM   #1
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
BaP + Dual fuel pump
Is it ok to use both BaP & Dual fuel pump setup for +600 rwhp or the dual fuel pump is enough ?
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 08-11-2011, 08:38 PM   #2
Synner
Drives: cars
Both can be done but it depends on when you run out of fuel. I'd talk to each pump manufacturer and see what they think the limits are before you need to add the BAP as each one will be a bit different and depend on your engine setup.
Old 08-11-2011, 08:40 PM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Ahmad
I'm using both, no problems.
For the safety of the motor, at 600 or more HP, I would use both... The BAP is tied into the boost, the more boost, the more voltage...
Old 08-11-2011, 08:50 PM   #4
alssiri
alssiri's Avatar
Now i am @ 620rwhp & using both,but i see the fuel pressure droping @ high rpm close to 40psi & thought it is happening cause of using both,i thought maybe this is creating more pressure on the fuel lines & making it drop to 40psi !
Ahmad
2012 ZL1 A6 (SOLD)
Old 08-11-2011, 08:53 PM   #5
Synner
Drives: cars
Sounds like you might have a wiring issue on the BAP...? I know there were a number of people with similar issues and it turned out the wiring was on the wrong side of the module and it was readjusting the voltage back to stock. Might want to start looking there.
Old 08-11-2011, 08:59 PM   #6
alssiri
alssiri's Avatar
Actualy i had BAP on the car first when i was @ 6 psi & then added the Dual fuel pump setup after going to 7psi & now i am @10psi & not running out of fuel but only seen this drop @ high rpm .
Ahmad
2012 ZL1 A6 (SOLD)
Old 08-11-2011, 09:13 PM   #7
Synner
Drives: cars
Whos pump are you using? You shouldn't be seeing the drop in pressure like that. Sounds like one of the two, pump or BAP, isn't doing its job fully which is why I figured it might be wiring related. It could still be a ground or power wire on one of the two. There's people with similar setups and a lot more power that don't see it drop so something isn't right with it.
Old 08-11-2011, 09:20 PM   #8
alssiri
alssiri's Avatar
Thanks Synner, i have only 6k with this setup but i will check the BAP wiring & see i find.
Ahmad
2012 ZL1 A6 (SOLD)
Old 08-11-2011, 09:23 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
This,
If you are showing low pressure at high rpm, you are running out of fuel.. DO not go to high rpm again until this is all checked... you'll lean out and hurt the motor...
As Synner mentioned, there is no reason you should be dropping fuel pressure... If the BAP is wired in on the wrong side of the fuel pump, the cars systems will drop the voltage back to stock... 12 volts, and you will starve for fuel...
I am running a dual pump and the BAP, and substantially more HP, and my fuel pressure never moves... Steady 60 psi all the time... WOT or Idle... high or low RPM's...
Have it checked, make sure the BAP has power, and a GOOD ground, and that it is wired in after the module that controls the voltage... Also check to make sure one of the dual pumps hasnt quit...
But first and foremost, do not go WOT at high RPM's until you know for sure...
Old 08-11-2011, 09:40 PM   #10
alssiri
alssiri's Avatar
This,
SSE 4 2SS , my tuner says that i am not running out of fuel, it is just the pressure is droping he says, i will not go WOT till checking it out , thank you guy's
Ahmad
2012 ZL1 A6 (SOLD)
Old 08-11-2011, 09:51 PM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Ahmad
Remember this, these motors are designed to run at 58 psi fuel pressure at the injectors... Anything less than that and you are leaning the motor out... "running out of fuel..." your injectors are using more fuel than is being supplied... thats why the fuel pressure drops... I suppose like mine, your fuel pressure sensor is on the front end of one of the fuel rails...
Older fuel injection motors were designed to run at 43.5 psi if I remember correctly...
Old 08-12-2011, 07:53 AM   #12
ADM PERFORMANCE
Drives: Anything I want
Email me .
I have something for you
ADM PERFORMANCE is offline   Reply With Quote
Old 08-12-2011, 08:09 AM   #13
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
What is it you have Andy?, i have the same problem.
Version I
Jannetty Racing 550 RWHP Street Brawler Package,
Powered by TVS2300 Maggie
http://www.camaro5.com/forums/showthread.php?t=100385
Version II
416ci stroker/4L80e
701rwhp 750rwtq
build and tuned by
SPI-Performance
69 Rebel is offline   Reply With Quote
Old 08-12-2011, 08:58 AM   #14
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
At 600 hp i would think just a bap and one pump would be enough. Same goes for duel pumps the duel pumps should def be enought alone. Now a bap and duel pump you could have ALOT MORE hp than you have. Sure its not the injectors?
JLE58 is offline   Reply With Quote
Any feedback on the Livernois Dual Fuel pump set-up? Turbo99 Forced Induction - V8 40 04-09-2013 11:58 AM
"Drop in" Dual Fuel Pump Question 8aStang Forced Induction - V8 11 03-20-2011 12:49 PM
WTB a dual fuel pump set up kook Forced Induction 0 02-04-2011 07:40 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
