Old 08-13-2011, 02:54 PM   #1
usranger80
usranger80's Avatar
Drives: 2011 1LT "Bumblebee"
DIY for V6 Brake Pad change
I saw the DIY for the SS but nothing for the V6, I imagine they are quite similar except for a few steps though. ALso some conflicting info out there on whether or not to bleed the brakes if you are jsut changing the pads. I have done brake pads before but never on this car and I just want to make sure I get it right without messing something up. Got some Wagner Ceramic TQ's to put on to get rid of the annoying brake dust.
usranger80 is offline   Reply With Quote
Old 08-15-2011, 03:39 PM   #2
RedVictory
Luv my LS3
RedVictory's Avatar
Drives: Summit White 2010 2SS/RS M6 LS3
Ill be watching this, ive got new pads and vented rotors to install....sigh...
RedVictory is offline   Reply With Quote
Old 08-15-2011, 04:13 PM   #3
garcmol
garcmol's Avatar
You shouldn't have to bleed the brakes when your finished. However, when you are spreading the calipers, keep an eye on the brake fluid resevoir. If/When it starts to rise because your spreading the calipers and pushing fluid back into the resevior, you don't want it to overflow. Brake fluid can destroy some paint. GO SLOW too! You don't want it to jump out of the resevoir either, lol. A turkey baster or syringe can be used to remove some of the fluid if you need to remove some.
The Brembo DIY will work fine for removing the calipers because they bolt right up to the same holes on the V6.
edit: as long as you don't crack the bleeder screw or your resevoir is bone dry you do not need to bleed the brakes
Old 08-15-2011, 06:56 PM   #4
FLRS
FLRS's Avatar
Drives: 2011 1LT/RS
Excellent advice
Gibson Axle Back - K&N Typhoon CAI - CFD Tap Shifter w/ Hurst Plate - Oracle Color Shift 2.0 - Oil Catch Can
FLRS is offline   Reply With Quote
Old 08-16-2011, 12:10 AM   #5
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
step by step pictures?
Hellfighter is offline   Reply With Quote
Old 08-17-2011, 10:23 AM   #6
RedVictory
Luv my LS3
RedVictory's Avatar
yes please
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
KNS Brakes - Your Street and Racing Brake Experts KNS Brakes Suspension / Chassis / Brakes 50 01-21-2011 11:00 PM
DIY: ABL Color Change Tecca Camaro DIY & HOW-TO instructions & discussions 20 05-18-2010 07:50 PM
Dealer-Oil change or DIY? wlvrine Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 32 06-23-2009 10:45 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
