![]() Drives: 10 camaro Join Date: Jan 2011
ls3 Maro Bolt on's with tuning problem
hi,guys
I have an ls3 camaro.The mods are: Vararam Intake(tune needed) Lg SuperPro full exhaust PowerBond UP I have problem with my tune,my wideband shows 11.8 I need from you guys best tuning file for bolt on my tuner using HP TUNERS And our gas is 91 octane ![]() if you can attach the file I will be appreciate that thanks |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
so you have hp tuners and a wide band. just make the adjustments needed to set your a/f where you want it at wot
![]() Drives: 2009 Pontiac G8 GT Join Date: Sep 2009
Readers Digest version: Set your PE multiplier to the A/F you want to command, then increase or decrease your MAF airflow (more airflow for richer) to give you the A/F that matches your PE multiplier.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners. 2014 GMC Yukon XL Denali, Air Raid MIT, tuned. 2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile 2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile LS1,LS2,LS3,LS7 Custom Camshaft Specialist |
![]() Drives: CTSV Join Date: Feb 2011
Divide the stoich value in your tune by what ever you would like to command.
14.7/12.5=1.176 Enter that value into power enrichment across the board. Then adjust the maf and ve to hit that number as mentioned above |
first thing i would like to thanks all of you guys
but i guess nobody understood me,my tuner i think he not pro in tuning that why i want a good file so if anybody can attached the greatest file he have i appreciate that regards |
#6 |
you need to tune your vehicle , you cant just flash another person's file into your car and call it a day,, every vehicle is different
#7 |
knows 2 facts about ducks
yup. You could try PMing Ted Jannetty and see if he could write you up a tune.
#8 |
| Cat Backs & CAI Bolt Ons | Rencor | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 07-28-2011 09:19 AM |
| Cam only....No bolt on's | WICKEDSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 15 | 07-30-2010 04:55 PM |
| Bolt ons??? | Greycamaroguy | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 5 | 07-20-2010 01:29 PM |
| 12.58@111 Bolt Ons Only LS3 M6 STOCK TUNE (vid) | RamAir02 | Dragstrip and Launch Techniques Discussion | 17 | 04-18-2010 06:53 PM |
| P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 02:45 PM |
