Old 08-14-2011, 09:05 PM   #1
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
DIY:TICK Performance Stainless Braided Clutch Line
This Clutch line from Tick Performance replaces the stock piece and allows the fluid to flow faster than the stock line which is restricted. Similar to doing the "Drill Mod" on 4th gen clutch hydralics.
You will need
1. Tick Performance Clutch Line
http://www.tickperformance.com/tick-...010-v8-camaro/
1. Small bottle of DOT 3 brake fluid.
4. 1/4" vaccum caps
Tools required
Needle Nose Pliers
Mitivac 35 to 40 bucks at the local parts store. (Worth its weight in gold)
To make bleeding the assembly a bit easier I filled the Tick Line with brake fluid and capped the ends with the vaccum caps. To do this I poored some brake fluid in a small container and submerged one end of the line in the fluid. I then hooked the Mityvac up to the other end and applied vaccum to the line. Once the fluid was flowing all the way to the top, I removed the vaccum and quickly capped the top end with a vaccum cap. and then capped the other end.
Pics are below the instructions.
Step 1
Jack the car up high enough to slide under the car comfortably and suspend on Jack stands.
Step 2
Locate the clutch line next to the transmission on the drivers side of the bell housing.
Step 3
Remove the small bracket attached to the line and position the new line close by. Using the needle nose pliers pull down on the retaining clip untill it stops. This clip is not designed to come all the way out so do not try to remove it. Pull the stock line out of the fitting and cap it with a vaccum cap. Some fluid will drip out of the slave line so make sure you are not directly under it. Remove the vaccum cap from the new line and press it into the slave fitting until it is flush. then press the retaining clip back up into the fitting.
Step 4
Move to the top side and locate the clutch master cylinder. Push down on the retaining clip from the stock line that goes down to the slave. Same as underneath the car, it does not come all the way off. Just push down on the tabs from the top. I got mine loose with my finger. Pull the stock line out and cap it. Route the new line in and press it into the clutch master cylinder. Make sure it is seated all the way and return the clip to the locked position.
Step 5
Remove the stock line from the car. Ther is a bracket on the firewall hidden behind a wiring harness. It is hard to get to and the line is very secure in the bracket. Use patience, I could not fit any tools in that tight little space.
Step 6
Press the clutch pedal down with your hand. It will go all the way to the floor and stay there. Work the pedal through its full range of motion a few times to fill the system with fluid. Once the pedal comes up on its own sit in the drivers seat and pump the clutch pedal with your foot about 30 to 40 times. This will get most of the air out of the system. Bleed the system using the mitivac and replace the lost fluid in the resevoir.
Step 7
Clean up your mess and put the car on the ground.
Step 8
Enjoy!
Squintz Palladoris is offline   Reply With Quote
Old 08-14-2011, 09:56 PM   #2
SmittyTuck
Drives: a couple
nice write up!!! notice anything???
SmittyTuck is offline   Reply With Quote
Old 08-14-2011, 10:06 PM   #3
Squintz Palladoris
Thanks,
Yes, The pedal is a bit more responsive when released. Its shifts alot better in the lower RPMs. High RPM shifts are improved but still get an occasional grind on the 1,2.
These cars really need a better master cylinder. This will suffice untill one is availible.
I also ordered the Lingenfelter clutch return spring when I ordered the line from Tick. It was dropshipped from Lingenfelter and has not arrived yet. Once I get that on I will give my thoughts on it.
Brad
Old 08-14-2011, 10:09 PM   #4
SmittyTuck
Drives: a couple
Kick ass man!! glad you enjoy this mod, let us know how that spring works
Old 08-14-2011, 10:16 PM   #5
JETG
Drives: 2011 Camaro SS/RS
Might be stupid question but how do you bleed them on this car ??? Thinking about this and return spring and also GTO reservoir.
JETG is offline   Reply With Quote
Old 08-14-2011, 10:47 PM   #6
Squintz Palladoris
If you have a mityvac bleeding is a breeze. Even easier if you are running a separate resevoir for the clutch master.
On the stock resevoir getting the fitting from the mitivac into the proper position is a bit of a pain, but it can be done. I did it today.
For those that have never used this tool to bleed clutch hydralics I'll explain it. It is a hand held vacuum pump with a small resevoir and various tubes and fittings.
On the Camaro (Stock Resevoir) use one of the shorter fittings and work it down into the resevoir, pointed toward the drivers side fender. This is where the clutch master cylinder feed line is. Once it is inserted into the inside of the fitting that goes out to the master, pump it up untill it is around 15 inches of vacuum. The vacuum will cause the air bubbles to rise up through the tube. You will first see some fluid come up the clear tube towards the tool, and in that fluid you will see the bubbles. As the vacuum drops off keep pumping it back up untill you no longer see bubbles coming up the tube.
If you are useing a separate resavoir it is much easier as the fitting will drop right down into the hole it needs to go to.
Brad
Old 08-16-2011, 01:19 PM   #7
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
Thank you for the writeup Brad - very helpful! Let us know how the Lingenfelter spring works for you in combination with our line.
Matt@Tick is offline   Reply With Quote
Old 09-17-2011, 01:18 PM   #8
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Totally fixed my issue, lingenfelter spring and new braided line from tick. I also have tick's speed bleeder. overall amazing bandaid till Tick gets more of my money! :-)
Brad
The 2010 Sin is offline   Reply With Quote
Old 11-21-2011, 01:47 PM   #9
DocT
DocT's Avatar
Drives: 2011 Camaro 2LT - MT6
I have 2011 LT V6 with same annoying problem. You have a kit to fit the V6 and resolve the clutch sticking and high rpm shift failures?
DocT is offline   Reply With Quote
Old 11-22-2011, 12:04 PM   #10
Matt@Tick
Matt@Tick's Avatar
Just V8 for now.
Old 04-28-2012, 01:35 AM   #11
Ace1USMC
Drives: 2011 Camaro SS LS3
Here's a question...How the heck did you get the stock hard line outta the car???? (without cutting it up into more manageable pieces)
Sam
By His wounds...
Ace1USMC is offline   Reply With Quote
Old 05-13-2012, 01:00 PM   #12
MIKnam67
MIC
Drives: 2012 SSRS 6sp man Blk
Where can the 1/4" vacuum caps be purchased?
MIKnam67 is offline   Reply With Quote
Old 10-12-2012, 06:48 AM   #13
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
Subscribed for future reference
Sent from my Nexus S 4G using Tapatalk 2
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is offline   Reply With Quote
Old 10-12-2012, 07:32 AM   #14
james347
Drives: 2006 Crownline
Sam
Good question. I did this procedure (great write up by the way) and it is very straight forward and easy, except removing the stock line out. It took a lot of patience, and turning and twisting (no pulling hard!! because there is a wiring harness and other plastic stuff that could get caught up in the process) I ended having to physically bend part of the stock metal pipe to pull it up thru the engine bay. However the metal was flexible enough that it gave some, then went back to it's original shape. I have it hanging on the garage wall in case () i ever need to put it back on.
With the IdealG Cylinder and the tick line, I have done several full throttle/high rpm shifts and it's very smooth and peedle feel is great.
james347 is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Sticking clutch pedal issues - Tick Performance feels your pain! Matt@Tick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 185 12-22-2018 01:21 PM
2010 Camaro Exterior Stainless Steel Parts 15% off thru 2/10/10! RPI Designs Exterior Parts & Accessories 5 02-28-2010 02:28 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
