Old 08-15-2011, 05:27 PM   #1
SamSS
SamSS's Avatar
Drives: '10 Camaro SS
Arrow Paint Fading Already?
I've had my SS since December of 2009. I always park it in my garage unless I got out and I'm forced to park it in the streets or parking lots. I go to school so the car is parked for about 5-6 hours. Today I parked it in front of my friends apartment and was looking at the car, it isn't looking black. Looks like the black is fading almost. There wasn't that much dust on the car, maybe a little bit, I washed the car and used spray wax on Thursday. Should I be worried about this? Is it really fading or am I just being paranoid?
SamSS is offline   Reply With Quote
Old 08-15-2011, 05:30 PM   #2
ORANGA2D
ORANGA2D's Avatar
Drives: 2011 IOM 2SS/RS M6
Pictures would help, and no it shouldn’t be fading now, unless something is wrong or some type of chemical or “sanding” has occurred. As always you can have your dealer take a look.
ORANGA2D is offline   Reply With Quote
Old 08-15-2011, 05:33 PM   #3
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
Give it a shot waxing it and see where it goes. You could even try leaving it out in a good rain storm to see if that removes the fading look (not that rain is known to do that). Also, try a good paste wax, or even liquid, to really bring out the luster. I have heard that Black cars are difficult to keep pristine, but I wouldn't panic too much yet.
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
Old 08-15-2011, 05:35 PM   #4
ORANGA2D
ORANGA2D's Avatar
Ya good points, like stated try a good wash without the wax, then wax and see if it helps. It could just be build up from the spray wax giving it a haze look.
Old 08-15-2011, 05:38 PM   #5
SamSS
SamSS's Avatar
Has anyone with a black car ever used those black paste waxes? Is it any good?
2010 Camaro SS A6, Rotofab intake, Flowmaster American Thunder exhaust, JBA off-road pipes, PFADT sway bars and lowering springs, Dyno tuned by CMS
Old 08-15-2011, 05:46 PM   #6
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
you're paranoid. same thing with me. I'm going to use swirl & haze remover from adam's and see where that gets me. i know what u mean when u say it looks like its fading...but its not really.
SnoopyAce7 is offline   Reply With Quote
Old 08-15-2011, 07:07 PM   #7
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
Any chips in the paint?
shockandawe is offline   Reply With Quote
Old 08-15-2011, 07:19 PM   #8
suplex
suplex's Avatar
If there are, I highly recommend Dr. Color Chip to repair them.
Old 08-15-2011, 07:48 PM   #9
ibmrs
ibmrs's Avatar
Drives: 2011 2LT RS IBM
It is possibly an effect of the spray wax you put on thurs streaking once it was in sun. If so, just wash and wax it, should be fine.
Tampa Bay Camaros, Team LLT
ibmrs is offline   Reply With Quote
Old 08-15-2011, 07:59 PM   #10
SamSS
SamSS's Avatar
No chips in the paint. I'll use a paste wax the next time I wash the car to see if it makes it better
Old 08-15-2011, 11:47 PM   #11
doubletap407
doubletap407's Avatar
Drives: 2011 ls v6 blacked out
I use the black wax! First I wash it with quality car wash soap, then I used a clay bar to remove anything that might do any damage to the paint then I used the black wax as directed. When finished it's like shes had a new paint job ! However it's lots of work . but well worth it!
doubletap407 is offline   Reply With Quote
Old 08-16-2011, 12:24 AM   #12
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Just a guess....it sounds like you are seeing a film haze from the spray wax you are using. Spray wax should only be used to clean or detail a small area (fingerprints, bird crap, etc.). I wouldn't use it to "wax" the entire car.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 08-16-2011, 12:59 AM   #13
ooojerry
ooojerry's Avatar
Drives: FAST
I'm a detailing junkie and two of my prior cars were black. Black with no metal flake like to "fade" into a brownish black. Its just the paint being normal. I'd suggest if you'd like to go crazy....Wash it. Clay bar it. If you want to remove defects get a good cutting compound and it'll remove the swirls and etc for the most part. Here is the important part. A GOOD polish this will bring the depth back to the black and then you use a good sealant (ie wax). If youre using a more expensive wax you will get the streaking cause the wax "sweats" due to the humidtity and carnuba content....Anyway if you need some recommendations PM me.
ooojerry is offline   Reply With Quote
Old 08-16-2011, 01:12 AM   #14
brooks35
brooks35's Avatar
Drives: 57Chevy TrailblazerSS 73Camaro
It is probably just in need of a good polish job. Get a "soft" pad and a 3M polish.Any paint supply shop will have it. This will remove the fine swirls / scratches that make the black paint look faded. With black paint you just need to be very careful what type of wax you use also. Make sure you do not use any wax with "cleaners" in them. This is actually a fine "grit" and will leave swirls in the paint.
brooks35 is offline   Reply With Quote
Understanding Paint Correction-The Nitty-Gritty Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 29 03-02-2012 04:51 AM
Paint Chipped on Rear Fascia rwmiller56 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 08-10-2011 06:49 PM
A few questions about custom paint jobs. nardox Cosmetics and Lighting Modification Discussions 11 02-21-2011 09:34 AM
Megatron Visits The Junkman for some Paint Correction Education! Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 28 11-16-2010 05:19 PM
Open question to dealers regarding paint discrepancies TommyTSquared Camaro Price | Ordering | Tracking | Dealers Discussions 4 08-21-2010 11:05 AM
