Drives: 2011 Camaro SS Summit White Join Date: Apr 2010
HELP! Suspension wouldn't re-compress!
So I jacked my car up for an oil change and when I brought her back down the front suspension was about an inch higher than it was previously. WHAT THE HELL COULD HAVE CAUSED THIS! Btw, after a short drive it went back down. Someone please explain.
I'm really freaking out here, any help is much appreciated
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2SS/RS Join Date: Jul 2009
Your letting all the weight Off, charging the spring/ shock up..it goes back down.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst- Mods: Corsa catback, SSE, Vararam |
The suspension just doesn't return to its normal ride height until it is jostled around a bit. Its normal.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Tires were at a different camber angle in the air with the suspension unloaded. Went setting it down, they can't just slide back out across the concrete. That's why alignment racks have pads on bearings where the front tires sit.
#6 |
Drives: 2011 SS/RS Join Date: May 2011
Go drive the car around the block.
#7 |
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
RELAX DUDE!!!! Just move the car about 10 feet and it will settle.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
#8 |
![]() ![]() Drives: Awaiting 2014 C7 Join Date: Sep 2009
Go for a drive like others have suggested. It is perfectly normal
Awaiting 2014 C7
#9 |
![]() Drives: 2015 Corvette Z06 Join Date: Apr 2011
Russel James is spot on! Exactly the cause.
What's more chicken---- than f------ with a man's automobile? I mean; don't f--- with another man's vehicle! - Vincent Vega
#10 |
![]() Drives: 2006 mazda cx-7, 2005 C55 AMG, etc. Join Date: Aug 2011
Dont worry about it man, its all good!
#11 |
lol
| Tags |
| compress, issue, jack, suspension |
| *SALE* Pedders Suspension available from D Revolution Motorsports *SALE* | DREV LSX | Suspension / Chassis / Brakes | 41 | 01-14-2012 12:30 AM |
| Save $$$ with Pfadt suspension packages from Apex Motorsports | Apex Motorsports | Suspension / Chassis / Brakes | 75 | 12-13-2010 10:29 AM |
| Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 03:28 PM |
| JDP Motorsports and Spohn Performance! Dial in your suspension! | JDP Motorsports | Suspension / Chassis / Brakes | 0 | 12-03-2009 02:59 PM |
| Pedders suspension already for the Camaro | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 75 | 10-21-2009 08:25 PM |
