![]() ![]() Drives: 2011 Camaro RS M6 Join Date: Jan 2011
V6 Oil Pressure, what is everyone showing?
I finally got my gauge cluster and installed tonight. What is everyone showing on their gauge for oil pressure on the V6? At idle mine is about 25 psi, but as soon as the engine goes to 2000 rpms, it pegs the gauge at over 70 psi. Cruising in 6th gear at 1700 rpms or so it is running about 60 to 65 psi. If this is normal, why not a 90 psi gauge?
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
About the same
Let's go Rangers!
normal. Notice there is no red line on the high end.
having FUN now 13.66@101
This has been documented before. All is good with what you are reporting.
Thanks everyone. I still wonder why they didn't design the gauge to go to 90 or 100 psi instead so you get an accurate reading when accelerating. Has anyone hooked up a mechanical gauge to see what this engine really has for pressure at high rpms? I'm just curious.
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
I was wondering the same thing myself. 25 is a reasonable idle pressure and could be something to do with the mechanics of VVT. As for 100psi it should be that way. 70psi max? Pssshhhhh.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
Glad this thread exists as I was wondering the same thing.
Yesterday evening, I was "cruising" between 80-90 mph for quite a few miles and saw my oil pressure at 60-70 psi. I remember thinking to myself "hhhmmm...I wonder if that's normal" as I'm not accustomed to seeing any of my gauges at or near their peak reading (except when my old Honda overheated). When I slowed down to 65 mph, oil pressure returned to 30 -where it usually is under normal driving conditions. Phew!
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
#8 |
I noticed the same thing when I first got my car. The general answer going around at that time was that the gauges were optimized for the v-8 and they used the same ones for the v-6 to save money.
2010 SIM 2LT/RS| Mods: Gibson Axle-backs, Body Color XM Antenna, RPI Stealth Mud Flaps
| A Look at GM's Oil Life Monitoring System | franknbeans | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 168 | 08-07-2024 02:29 PM |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 09:51 AM |
| AFM turned off by my dealer???? | fastfreddie | 5th Gen Camaro SS LS LT General Discussions | 95 | 08-25-2012 03:55 PM |
| Oil Catch Can Where to buy | Pollock | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 19 | 05-01-2011 11:43 PM |
| First Camaro DIY Oil Change = 4 Hours -FML | Infern0 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 63 | 09-25-2010 04:18 PM |
