Old 08-21-2011, 09:21 PM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Weak Timing Chain on 2010's
I know GM addressed this at some point, but anyone know when? Trying to figure out if mine is one of the lucky 2010's that has a crappy timing chain.
BaylorCamaro is offline   Reply With Quote
Old 08-21-2011, 09:49 PM   #2
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Drives: Not a Camaro
I thought it was for our engine when used in other model cars, I haven't heard of any Camaros having this issue.
bossbunny is offline   Reply With Quote
Old 08-21-2011, 09:54 PM   #3
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
At over 80,000 mile on my Camaro, no problems.
PieNsky is offline   Reply With Quote
Old 08-21-2011, 11:45 PM   #4
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Well I'm not sure, I know Scrming talked about his wife's vehicle having the LLT and mentioned the weak timing chain. Not sure if our's actually had the same chain or not, but I thought early 2010's did.. maybe not..
Old 08-22-2011, 01:01 AM   #5
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
I see you have SW headers. LT's I assume? Which exhaust do you have them paired with?
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 08-22-2011, 05:27 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Found 2 threads on this subject. Along with the answer I posted a while ago that discussed this change in part numbers.
http://www.camaro5.com/forums/showth...6+timing+chain
http://www.camaro5.com/forums/showth...light=12616609 post # 66
Checked into this question, here is what I found.
12633451 and 12623452 were in production from 15July10
Timing chains are the same in all of the 3.6 engines
#12616609 for the primary chain
#12616608 for two of the secondary chains
They HAVE been changed up to #12633451 for Primary and #12633452 for secondaries.
Hopefully this will correct the issues.
It looks like GMPartsDirect caries all 4 part numbers.Primary ChainGM PART # 12616609CATEGORY: AllPACK QTY: 1GM LIST: $43.47OUR PRICE: $25.28Secondary'sGM PART # 12616608CATEGORY: AllPACK QTY: 1GM LIST: $49.56OUR PRICE: $28.82Primary ChainGM PART # 12633451CATEGORY: AllPACK QTY: 1GM LIST: $42.84OUR PRICE: $24.91Secondary'sGM PART # 12633452CATEGORY: AllPACK QTY: 1GM LIST: $49.11OUR PRICE: $28.55
Old 08-22-2011, 05:33 AM   #7
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Cat does not mean the VIN# after need to be changed yet? Or did the factory make the necessary changes during build time?
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 08-22-2011, 06:04 AM   #8
rtcat600man
After that build date posted the chains are to the new ones.
Old 08-22-2011, 07:34 AM   #9
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
hmm. my build was 9/22/09 so I may need to swap at some point.
esperman is offline   Reply With Quote
Old 08-22-2011, 08:35 PM   #10
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I believe we discussed this on this forum or the other one, but if you keep the oil changed regularly and use high quality oil you shouldn't have an issue. Right?
Old 08-22-2011, 08:37 PM   #11
rtcat600man
Correct. That is what I have been told by my sources. Just keep the oil changed and you should be good. The issue was when the oil was left in to long and the dirt and friction started to wear on the chain.
Old 08-23-2011, 05:39 PM   #12
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Well the wife's Acadia is getting some new chains... AGAIN! This set lasted 50,000 miles. I know my wife gets her oil changed regularly... Its covered under warranty... But still...
scrming is offline   Reply With Quote
Old 08-23-2011, 06:35 PM   #13
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
What are the warning signs? Do they get noisy or does the timing start bouncing all over the place or what?
Old 08-23-2011, 06:50 PM   #14
scrming
scrming's Avatar
No warning signs, just check engine light.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
LLT Engine Internals Build The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 69 08-24-2017 01:29 PM
Timing belt or timing chain? tradosaurus Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 37 08-10-2012 07:21 PM
replace the timing chain?? trans665 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 06-09-2011 09:20 PM
New timing chain tensioner necessary? yotaman96 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 05-03-2011 04:40 AM
