Need some opinions on these Dyno results.... LLT @ 350HP?
OK. OK. OK.
I am a dyno newbie. Did my first run Tuesday morning. What a blast. I thought I had all of the questions I wanted to ask nailed down, but with all the excitement, I forgot most of them. ![]() Basically, when I finished up, I just assumed that these numbers were "corrected" for loss through the drivetrain. It did seem a bit high (I was hoping for something in the 330 HP range). I just figured that the numbers at the wheels were buried in the data somewhere. I got home after work (I went during work hours - shhh) and started looking a little harder at the printouts. The estimated 1/4 mile time looks about right. But the other two seem way out of wack. Anyone (of all of you dyno gurus out there) know if they might have totally biffed my run, or if they might be just reporting a "calculated" crank number? I've called them (left a message) and sent an email and haven't gotten a response yet. I will probably stop in there in the next day or so and see if I can catch them face to face. Of course..... 351HP and 293 torque ain't to shabby. ![]() Thanks for any insight.
All I need are some tasty waves and a cool buzz and I'm fine (and of course a hot Camaro doesn't hurt).
![]() ![]() Drives: 2010 Black Camaro 2LT/RS Auto Join Date: Apr 2010
I might be wrong on this, but I thought most pulls were done in 3rd gear
BackInBlack
Performance:Vararam cold air intake |
#3 | |
I did another run and maxed it out at 155. It was pretty cool seeing "Vehicle speed limited to 155" on the DIC.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Well, one thing we know is your car is not making 350 wheel horsepower lol, although that would be SWEET!
I'm thinking something is off as I've never seen a dyno that didn't show rear wheel numbers. The numbers you posted above look closer to what you'd have at the crank, although I think they are probably even higher than what your crank output actually is. Most pulls are done in 3rd, but some have been done in 4th as well.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
![]() Drives: RS Victory Red/BS V6 Join Date: Aug 2010
WOw, what did you put a 200 shot of nos LOL, thats insaine... im sure thats not rear wheel deeefinately not... but it could possibly be crank, but still thats high.. id reccomend a new dyno somewhere else preferably a dynojet or something :P nice car though!
2010 Camaro 2LT RS M6 VR/BS Flowmaster AMT Axle Back Vararam Ram Air Intake P13 Plazma Bulbs DT Shorty Headers Heritage Grill Blacked-Out Taillights and Side Markers ![]() |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
Wow my Dyno wasn't even close to your numbers ! Best I could pull was 257 HP at the rear wheels in third gear ! And thats with headers.. axel back..and a Cai setup . What mods does your car have to pull those kind of numbers ?
#7 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
Facts you should know about electric current dyno(mustang, dyno dynamic, etc.)
These types (Mustang, Dyno Dymamics) of dynos utilize rollers that usually have very little mass, hence they’re not a true inertia chassis dyno. In order to present any type of physical load on the vehicle, there needs to be a PAU (power absorption unit). Typically this PAU is in the form of electrical coils that utilize eddy current technology (think of this as a big electric brake). Now having a big electric brake is all very nice, but we need to use a chassis dyno to measure power at the end of the day. Since the mass of the rollers isn’t known (like a Dynojet), there needs to be a means to measure power, so how this is done is with a torque cell, or sometimes referred to as a strain gauge. As the big electric brake absorbs power, the strain gauge is actually measuring torque. Now here is the kicker, the strain gauge really doesn’t know the difference between 2 ft-lbs or 200 ft-lbs until you calibrate the device, so in doing this, you’re introducing a potential margin of error and inconsistency. This would apply to any "loading type dyno" that uses eddy current load control and a strain gauge, even our own 224xLC which is a hybrid inertia / electric load style dyno. The strain gauge needs to be calibrated to make it consistent and repeatable, but there are other user defined (by the dyno operator) variables that makes things very interesting. Once the strain gauge is calibrated properly, the dyno operator must enter certain parameters about the test vehicle that determine the rate of acceleration the dyno will allow, and are ultimately directly responsible for the power and torque readings that are displayed on the graph (WOW!). At this point you may have connected the dots and are either appalled, or still rather comfortable with the dyno graph you have in your hands. The question that pops up, “my car made 280 rwhp on a Mustang dyno, what would it make on a Dynojet”, should be countered with the statement, “I’m not sure, but I do know this, you’d most likely get 10 different numbers on that same Mustang dyno, let alone another Mustang dyno that’s installed in the field”. Now this isn’t meant to bash Mustang dyno or Dyno Dynamics, but some dyno owners just can’t resist “tuning the dyno”, instead of tuning your car. If you’re “measuring stick” isn’t consistent day in and day out, then how can you be certain your tuning and modifications are actually working? If these dynos are set up properly, they can provide relatively consistent and repeatable results. For what it’s worth, we do not allow dyno operators to adjust “certain parameters about the test vehicle” on our hybrid electric brake / inertia 224xLC dyno. So, in any case, there are a couple ways that even when testing on the same model Mustang dyno or Dyno Dynamics dyno (or even the same exact unit) that the numbers are subject to a few variables. These variables are ultimately responsible for the power numbers reported from the test session. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
He installed that electric supercharger and now has proof it works.
Or the dyno was wrong. |
#9 |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
Mustang Dyno. nuff said
#10 | |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Im not Gray any more !!
#11 |
All great comments my Camaro5 brethren. Shhh about the electric supercharger (actually, I'm using two Craftsman Model# 79481 gas leaf blowers).
![]() I know I'm definitely not pulling 350 at the rear wheels. 350 at the crank? Probably not. More like 330 (crossing my fingers). I'll be stopping in to see these guys tomorrow and see what they can tell me, and yes, I see another dyno run at a different shop very soon. Thanks!!
![]() Last edited by Spicoli; 08-26-2011 at 06:18 PM. |
#12 | ||||||
Never enough time
Drives: 2010 Camaro SS 6-spd Join Date: Jun 2011
You should ask your friendly Mustang dyno operator if he calibrates regularly, and if so when was the last time he calibrated. Typically, a "zero balance" is done prior to each vehicle running on the dyno. In the 6 years I've owned my dyno, I've never seen the load cell calibration out of range by more than a couple hundredths of a volt (equal to a few tenths of a pound mass). Quote:
I'm not sure what you point is here, but if you're going to bash other dynos, you might as well get your so-called "facts" in line first. There is already so much misinformation out there that you really don't help the tuning community by continuing to spread your FUD.
Personal mission: Killing the Dynojet vs. Mustang hype
#13 | |
Never enough time
Like anything else dyno-related, as long as you're comparing apples to apples you'll be fine.
#14 | |
MARO MAN
Drives: Orange 2010 Camaro 2RS Join Date: Feb 2011
2LT-RS/nitto invo/hankook venus/straight pipes/slp blackwing air filter/5% window tint all windows/3.00" tips/hood and hockey stripes
| Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 48 | 12-08-2018 03:37 AM |
| Scrming's Airaid and Injen Dyno results... | scrming | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 212 | 06-28-2010 04:28 PM |
| Magnuson install at RPM motors dyno results | tlamb2 | Forced Induction - V8 | 8 | 04-06-2010 08:32 PM |
| Dyno Results on L99? | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 05-12-2009 11:53 PM |
| BUDWEISER SHOOTOUT LINE UP | CamaroScotty | General Automotive + Other Cars Discussion | 22 | 02-07-2009 08:03 PM |
