Banned
what is the best oil for FI apps, honest opinions
I have done so much reading, and in all honesty I am more confused !!! So what oil is every one using for turbo and or super charged apps and why. PS I didnt post this in the oil section because its only for the FI crowd.
user bann'd
Drives: Chevy SS Join Date: May 2009
A little birdie once told me "A little something we recommend- always
Run 15w 50 mobil 1" I think i'll listen to this guy, he knows a thing or two...
![]() Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
I just stuck with the mobil 1 i had been using.
Banned
I was told 15w in a new engines wasnt good...that a 0 or 5 weight was recommended...But what I really want is the top brand..the weight is basically adopted to temp. So lower 0 are used in a colder climate and the higher numbers in a hotter ambient climate. But who can tell me the best overall brand in any climate..all other things equal..so far i am inclined to think amsoil based on all the research and inform they have put out. any one care to chime on this?
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
Oil brands are like the M6/A6 arguments.....you will never ever find consensus...everyone has different favorites based on preferences or opinions and reality is that both are great.
Same applies to oil. Run any good brand and change it regularly and you are good to go. |
#6 |
Drives: 99' Camaro 404 TT Join Date: Sep 2010
Depends on where you live.
Canada Cold, Thinner Stuff Arizona hot, Thicker Stuff Typically I would follow ur Manufactures oil recommended and weight for normal driving use anyways. This goes for 95% of you. GM recommends Moble 1, and she’s a very good oil. Amsoil, very good, personally not a fan of Royal Purple engine oil, I've seen the inside of a LS engine that religiously used RP, did not like the purple dye I found in the engine. Royal Purple SyncroMax Tranny fluid, very good, ! As well as Rear end Fluid. For heavy high rpm driving, I would check and change the oil more often as well as run a little thicker oil. I typically run 10w 30 Full Syn during the summer, 5w/30 winter. Track use high rpm, 15w50. Here are good reads on Oil, & Oil filters. Oil Filter Study, AC DELCO did not test well. :( http://www.gmtruckcentral.com/articles/oilfilterstudy.html Here is a consumer reports motor oil test. http://www.unofficialbmw.com/all/misc/all_oilfaq.html Have fun ! Most important thing, Check your oil often!! I've seen many LS engines with low oil come through, due to their driving habits, causing premature bearing wear if not checked often. Remember, the harder you are on the engine the more oil it will consume, it's only natural. Clint |
#7 |
user bann'd
The guy that shared this with me is some character named Andy... from some shop called ADM.... I think he has built a few cars....
#8 | |
Banned
#9 |
![]() Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
My friend has a GT 500. His manual says 5-50. Ford sells this synthetic oil.
#10 |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
My builder uses Amsoil, thus, I use Amsoil, he built and supports the motor...
I also change my oil every 2500 miles. Period... Like I've said before, my motor, my turbo's, and my money... call it what you will...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#11 |
![]() Drives: Camaro Join Date: Jun 2009
First and foremost the most important thing is to keep the oil fresh and clean.
Synthetic oil is a must. Most off the shelf brands. (i.e. mobil 1, valvoline synthetic, castrol edge, etc...) are using the exact same standards, brands such as mobil 1 actually dropped the quality of there oils to meet the new standards. (they figured why be better if we're not gona get credit for it). Most of my clients up into the 600rwhp range receive 10w-30 Mobil 1, and we've been very happy with it. However for the "Big dog cars 800+" we step it up to either Amsoil, or Torco Oils which use a much higher grade base 5 oil. Hope this helps. Mike Haddad |
#12 |
Banned
thank you all for the opinions, points all well taken. I will pushing about 750-800 at the engine..so i think imma go amsoil...btw his was the only oil that rotary engine racers used back in the day...that says alot.
#13 |
![]() ![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
If the the folks that built the engine recommend 5w-30 and you think 15w-50 is better.....would 75w-140 be better yet?
#14 |
Banned
i know from just common chemistry that the thinner oils are better...its the temp degradation that determines the point where an oil loses its protection...Obviously syns are much better in general...I just want the best all around brand. Old motor head i suppose u where being sarcastic. I like humor but i am asking for serious opinions..if u want to go bash what some one stated or me for just agreeing on here do so after u have valuable input.
| DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 07:53 PM |
| Gas prices WILL go lower... | ga0358 | General Automotive + Other Cars Discussion | 113 | 05-02-2011 02:16 PM |
| GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 | SQUALO | Canada | 56 | 04-21-2011 04:19 PM |
