Old 08-28-2011, 08:20 PM   #1
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
ULTIMATE CAM Specs/ Info thread for the LS3/ L99!!
I know this has been done before..but maybe this time we can get a sticky on the thread and make this a very informative piece for members to look at when planning for a cam.
Post up your cam and who/where you got it, then any videos applicable, followed by dyno charts (again if applicable) and finally cam specs and any supporting mods etc.
Again, i know there are some smaller threads like this..but i think i as well as many others would like to see one comprehensive thread with all cam info etc in one place. Also, free cam discussion is welcome for any who want to. I will add my cam videos/ info once i get my cam installed.
anybody want to bite and start us off?
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 08-28-2011, 09:04 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
SNL performance V4 CAM and ARH LT headers which really make it sound pissed
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-28-2011, 09:16 PM   #3
mike25
mike25's Avatar
awesome sounds great! Thanks for the post- lets add to this and make this an informative thread for everyone
Mods:
Old 08-29-2011, 10:35 PM   #4
stb3222
Drives: 2010 2SS
Will post Dyno with the nitrous later this week
Custom Lashway Grind, Kooks Long Tubes, MBRP Catback, FAST 102, AFE Cold Air
stb3222 is offline   Reply With Quote
Old 08-30-2011, 04:26 AM   #5
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
Mods are in my sig and I'm pretty sure that everyone know the specs on the TSP 231/236 cam!! I will also be getting the heads ported by Darin Morgan when I get back from Iraq!! Once that is done I will be reposting the results! Hoping to get closer to my goal of 500/475 to the wheels on the motor and running consistant mid to low 11's at 120+!! Wish me luck!!
If not then here they are!!
duration 231/236 lift 641/614 LSA 112!
Name:  After the Cam Dyno Sheet.jpg
Dyno Run
Track Runs after going to Lethal
High Rev/Idle with and without Cam
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 08-30-2011, 04:21 PM   #6
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
LG G6X3 Manual Transmission
LG G6X3 Automatic
Both of the Above cars had the following:
  • LG Super Pro exhaust
  • LG G6X3 cam kits
  • Underdrive crank pulley
  • Cold air induction
  • ported throttle body
  • *the automatic is using a 3600 stall converter
Anthony @ LG Motorsports is offline   Reply With Quote
Old 08-30-2011, 05:00 PM   #7
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
It would be nice if everyone could include the gains since that will vary much less dyno to dyno than the peak hp will. Maybe update a chart in your first post with results for each cam.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 08-30-2011, 05:10 PM   #8
kaler
kaler's Avatar
LG G6X3 Automatic
  • LG G6X3 cam kits
That auto should put a a$$ woppin on a lot of cars at the track. Was the 100+ from just the cam or everything listed? Those are some stout numbers either way especially considering you are running it thru a big stall.
Old 08-30-2011, 05:36 PM   #9
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
Kaler..... Will you post you vids and dynos?! I'm getting the TSP VVT 3 cam & ported heads kit too and want to hear it.
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
SilverSS3108 is offline   Reply With Quote
Old 08-30-2011, 05:38 PM   #10
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
My Lunati Voodoo Cam:
http://www.camaro5.com/forums/showth...ghlight=lunati
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 08-30-2011, 05:51 PM   #11
The yellow SS in my post, I did not have a chance to do a base line as he did all of the work.
Old 08-30-2011, 05:52 PM   #12
The auto car already had cold air and mufflers on it when we baselined it....but all of the other components were added to the after numbers. I have not done a cam of that size without full exhaust on it.
Old 08-30-2011, 06:57 PM   #13
jlugo
Drives: 2014 1LE 'Summit White'
Ok, lets do this one more again!...
Mods;
_CMC-30 227/239 cam (duration 629/623 - 114 LSA)
_SLP Underdrive crank pulley
_Ported throttle body
_Airaid MXP Cool Air
_MSD Plug Wires w/NGK-TR55 Plugs
_Doug Thorley 1 3/4 "Tri-Y" Long Tube Headers w/ off-road down pipes
_Mufflers Delete
_LSR Tri-Ax Short Throw Shifter
475 RWHP & 430 ft.-lbs torque
1st Start;
Dyno:
1/4 mile ET; 12.61 / DA 2854.Corrected: 12.31 (with Conti DWS tires)
jlugo is offline   Reply With Quote
Old 08-30-2011, 07:53 PM   #14
kaler
kaler's Avatar
Heading back to the dyno tomorrow to finish up the tune.
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 612 09-06-2024 09:00 AM
Vengeance Racing Cam Kit Plus!!! L99 Conversion!!! American Racing + Vararam Kevin@V V8 Bolt-Ons & Tunes 19 11-02-2011 09:40 AM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
**LG L99 to LS3 Conversion G5XB Cam and Magnacharger TVS 2300 Results** Bobby @ LG Motorsports Forced Induction - V8 31 10-27-2010 11:26 AM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 02:14 AM
