Old 09-01-2011, 10:25 PM   #1
GreyMare SS
GreyMare SS's Avatar
Drives: 2010 Camaro SS L99
Hey HP Tuners, How do you turn off the AFM?
I am new to tuning and can't find where you go to shut down the AFM. If you HP wizards out there can point me in the right direction. I'm still learning the software, so if you can be specific i would be grateful. Thanks in advance and hope you guys can help a newbie out!!!
GreyMare SS is offline   Reply With Quote
Old 09-01-2011, 10:56 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
open your file, click engine, then fuel, then COT lean cruise, then DOD disable
Old 09-02-2011, 08:34 PM   #3
GreyMare SS
Thanks, That did the trick
Old 09-02-2011, 11:40 PM   #4
Vitllnk
Drives: 2011 SS Conv Inferno
Are you guys talking about cutting off afm through preditor or laptop???
Vitllnk is offline   Reply With Quote
Old 09-02-2011, 11:42 PM   #5
Vitllnk
I don't know nothing
Old 09-02-2011, 11:44 PM   #6
Vitllnk
if you turn off afm will engine still cruise on 4 cylinders??
Old 09-02-2011, 11:45 PM   #7
jeffswhitess
Drives: 2010 ss2 white w/gold stripes
Wheels
What wheels do you have on your car! Do you have a better pic. Thanks Jeff
jeffswhitess is offline   Reply With Quote
Old 09-03-2011, 12:03 AM   #8
Vitllnk
anybody willing to tell me how to get started?I downloaded preditor tune myself...That's all I have ever done....I also have the cable to connect to laptop....
Old 09-03-2011, 06:02 PM   #9
Vitllnk
Hey camaro1.........Do I change this through preditor or laptop???Do i have to have a program to use laptop??? I'm trying to learn how to make my car run better...Thanks..
Old 09-03-2011, 09:26 PM   #10
DieselDork
DieselDork's Avatar
Drives: 2010 RS/SS
OP states that he is using HP Tuners. http://www.hptuners.com/
It's a laptop program.
DieselDork is offline   Reply With Quote
Old 09-03-2011, 10:47 PM   #11
Vitllnk
thanks
Music for the Maiden Voyage? LSxcellent 5th Gen Camaro SS LS LT General Discussions 1088 05-28-2012 12:43 AM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
L99, if you turn off/tune out afm do you loose mpg? G.E. 5th Gen Camaro SS LS LT General Discussions 42 12-06-2009 09:20 AM
Fall Cruise - Sunday October 18th Zeeman28a Canada 46 10-21-2009 10:11 PM
Just got off the phone with Borla! L99 + AFM look here HeavyD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-17-2009 03:05 PM
