Old 09-02-2011, 05:08 PM   #1
Shesabeast
Shesabeast's Avatar
Drives: 2011 Camaro SS/RS
Clutch Noise, rubbing sound while turning at low speed?
When im in 1st or 2nd, turn at low speed, 10mph or under, i hear and feel a rough rubbing sound coming from the rear end. Usally backing out of driveway, pulling out of a parking space, things like that. Any thoughts on what it could be?
Shesabeast is offline   Reply With Quote
Old 09-02-2011, 05:18 PM   #2
Bill F
Bill F's Avatar
Drives: 2011 CGM 2LT/RS 2005 Silverado Z71
There is a TSB out for this. Something to do with an additive for the rear end fluid. I'm taking mine in Tuesday to have it done. I have a LT with 2200 miles, BTW.
TEAM LLT
VMaxx TB, MRT v1, Roto Fab CAI, Custom Painted Bowties, DT Headers(On order!)
Bill F is offline   Reply With Quote
Old 09-02-2011, 05:23 PM   #3
Shesabeast
Shesabeast's Avatar
Cool... Glad it's a simple fix.. I've got an SS with 2500 miles on her, so it had me concerned.
Old 09-02-2011, 05:40 PM   #4
Bill F
Bill F's Avatar
Apparently it affects Camaros and Vettes with a posi rear end.
TEAM LLT
Old 09-02-2011, 05:44 PM   #5
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Do you know the TSB number? Or have the text of the TSB?
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 09-02-2011, 05:54 PM   #6
Bill F
Bill F's Avatar
I got it in another forum, give me a few mins. to find it.
TEAM LLT
Old 09-02-2011, 05:57 PM   #7
Bill F
Bill F's Avatar
Here you go. Check out page 7 and 8 of the attached pdf.
PI0137A: Rear Axle Chatter Type Noise on Low Speed Turns - (Feb 24, 2011)
Subject:
Models:
2010-2011 Chevrolet Camaro
Equipped with Limited-Slip Differential (RPO G80)
This PI is being revised to add the 2011 model year. Please discard PI0137.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on a chatter-type noise from the rear of the vehicle while making low speed turns.
This condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise.
Recommendation/Instructions
Important: Prior to adding the limited-slip axle additive, the bottle MUST be shaken vigorously for at least one minute to mix the additive thoroughly, then immediately poured into the differential.
Drain and refill the rear differential with new fluid, GM P/N 89021677 (in Canada, use P/N 89021678) and additive, GM P/N 1052358 (in Canada, use P/N 992694). Refer to the Differential Oil Replacement procedure in SI.
Once the differential fluid has been changed, the vehicle must be driven in eight tight figure eight maneuvers to heat the fluid and allow the additive to be worked into the clutch plates
TEAM LLT
Old 10-14-2012, 01:20 PM   #8
CTS
Drives: 2021 Sierra Denali 6.2L/10sp CC 4WD
This has always been a problem with GM and limited slip differential (posi). They use cheap low bidder gear lubes. Get ride of the GM stuff and use AMSOIL, Red Line or Royal Purple synthetic 75W-90 gear lube.
My new 2009 CTS had the have the gear lube replaced and additive used before I had 500 miles on the car. Less the 500 miles later you could hear the clutches grabbing/releasing on turns and sometimes a banging noise when slowign down. I insisted they install AMSOIL Severe Gear 75W-90 instead of GM crap and to this day, 3.5 yrs later I have not heard one noise from my rear axle. Factory fill lubes a low bid. If you continue to use the GM lube you will continue to have this problem. GM is stuborn, they will never recommend any lube that does not make them money.
PS - Way back in 1970 my new Chevelle SS454 did the very same thing and they changed the lube so many times that they refused to do it again and I had to live with it.
Mike
Synthoil Supply
  • 2021 GMC Sierra Denali CC Ultimate 6.2L
CTS is offline   Reply With Quote
Old 10-14-2012, 01:39 PM   #9
BigPopa71
BigPopa71's Avatar
Drives: Dark Knight
I had the same noise! They replaced all the seals and bearings in my rear. Problem solved!
BigPopa71 is offline   Reply With Quote
Old 10-15-2012, 08:53 AM   #10
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
13 month thread Necro...
My suggestion: Don't take it to Best Chevrolet in Easley, South Carolina
My VIN = 2G1FK1EJ9A9105017
Old 10-15-2012, 09:24 AM   #11
Easton091
Easton091's Avatar
I have same issue. Taking it in soon
Easton091 is offline   Reply With Quote
Old 10-15-2012, 10:14 AM   #12
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
This happened to me at 10k and at 20k, just change out the lube and be sure to add 4 oz of friction modifier, I used amsoil this time.
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
clutch noise, clutch problems, mechanic
Intermittent clicking noise at low speeds I8A4RE Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 01-07-2015 05:30 PM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
clicking noise when in low speeds in turning 2010rod Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-08-2009 08:04 PM
Tranny "Knocking" noise at low RPM Haloman1346 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-01-2009 08:23 PM
Clutch Noise? GLBL WMR V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 05-24-2009 01:04 AM
