Old 09-07-2011, 10:53 PM   #1
musclecargirl
musclecargirl's Avatar
Drives: 2010 2SS CGM w/IO Interior
All these mods and only 1 HP gain?
First, some background:
Two years ago, had my STOCK car (L99) dyno-ed.
Temp was in low 80s, humidity was 4%.
Two weeks ago, had my modified car TUNED (engine and transmision) and dyno-ed. Dyno shows I gained 1 HP and 15 ft. lbs torque.
Mods include:
- After market intake.
- Shorty headers.
- Highflow Cats.
- Catback exhaust.
Temp was low 90s and humidity was approx. 40%.
Real happy about the increase in torque. A little surprised by the HP results.
The shop attributed the lack of HP gains on the dyno to the temp and humidity. They suggested I bring the car back when the temps are lower and the humidity is lower for another dyno (which I plan to do).
I'm sharing this for a couple of reasons:
- I don't have the knowledge to either agree or disagree with the explanation provided for the HP dyno results. I'll know for sure when I take it back in about 2 months.
- Let others who might be considering mods/tune know to be careful about setting realistic expectations of what those mods/tune will get you (if you're expecting HP gains).
I'm happy with the mods and the tune. The car finally sounds like I want it to and the AFM is gone! Haven't driven it enough yet to know if there's any noticable impact on gas mileage.
If you've had a similar or different experience, I'd be interested to hear about it.
musclecargirl is offline   Reply With Quote
Old 09-07-2011, 10:55 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The power gains seem low to me. What were the final numbers, I'd say you should be around 340-350ish at least.
Rhino79 is offline   Reply With Quote
Old 09-07-2011, 10:56 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Were these at the same dyno?
SUX2BU is offline   Reply With Quote
Old 09-07-2011, 10:56 PM   #4
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Was the dyno runs (all of them) done at the same shop?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 09-07-2011, 10:57 PM   #5
musclecargirl
Good questions. I knew I'd leave something out.
Dynos were done at the same shop on the same machine.
HP two years ago (with stock car) was 347.
HP now is 348.
Old 09-07-2011, 11:02 PM   #6
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
Higher temperature and humidity are definitely knocking down your numbers. Don't worry so much about the dyno numbers. Take it to the track and see how it performs under real racing conditions.
stso634 is offline   Reply With Quote
Old 09-07-2011, 11:05 PM   #7
musclecargirl
Excellent suggestion. Can't wait till the next local Test/Tune. Really hoping to notice the increase in torque.
I'll post an update as soon as I have some results. I do have some track numbers/experience to compare it to so will be interesting.
Old 09-07-2011, 11:05 PM   #8
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Temps/Humidity Big Difference
I'm convinced temperature and humidty has a huge difference in dyno HP and Torque figures. I would really like to see your numbers in 70 degree weather. I would bet on a considerable improvment. Do you drag race, if so, before and after track times really tell the story.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 09-07-2011, 11:06 PM   #9
Rhino79
Rhino79's Avatar
Numbers sound about right then with good weather. Your car dyno'd well in stock trim, I agree with STSO, run it at the track see whats up with it.
Old 09-07-2011, 11:09 PM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Good dynos should account for weather changes. What kind of dyno was it?
Old 09-07-2011, 11:19 PM   #11
musclecargirl
Hope I got this right. First dyno was STD second was SAE.
Old 09-07-2011, 11:23 PM   #12
siriusdish
Drives: 2010 Camaro L99
Dyno jet? Mustang? ???
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 09-07-2011, 11:23 PM   #13
musclecargirl
Dyno jet
Old 09-07-2011, 11:24 PM   #14
siriusdish
Dyno jet
Sweet
2010 L99
