Old 09-08-2011, 09:06 PM   #1
starscream88
starscream88's Avatar
Drives: 2010 Camaro RS Transformers Edition
Send a message via Skype™ to starscream88
Question Air Raid Intake Question
I purchased an Air Raid CAI for my car around May or June of 2010. I had admittedly not done very much research, but there weren't a lot of options that I could dig up so I decided to go with it. I've not had any issues with it but I've read that there are some problems with it, although no one has said what they are. Anyway, should I be looking into replacing it, or should it be ok? Thoughts?
starscream88 is offline   Reply With Quote
Old 09-08-2011, 09:09 PM   #2
KMPrenger
KMPrenger's Avatar
Did you purchase it brand new or used? If it is new it should be a version 2, but you may want to be sure. The version 2 has an insert inside of the intake tube, while version 1 does not, and instead has a bit "air ramp" looking thing. You don't want version 1.
Version 2 will be fine, no worries!
Old 09-08-2011, 09:18 PM   #3
starscream88
I bought it new, I want to say it was a V2..but I'm not sure. Is there anyway to tell without taking the tube back off?
Old 09-08-2011, 09:25 PM   #4
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Just call David at Airaid. He will be able to help you.
chevy 3 is offline   Reply With Quote
Old 09-08-2011, 11:51 PM   #5
KMPrenger
KMPrenger's Avatar
Just take the filter off and grab a flashlight if you need it and peer inside. If you don't see a big hump, your good.
Old 09-09-2011, 05:14 PM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
or feel the bottom of the air tube just behind where the MAF sensor plugs in (closer to the filter). If there is an ident about as wide as the MAF and 2" deep, you've got a V-1.
If not you've got the V-2.
Nothing wrong with the Airaid CAI. It has performed in the upper 1/3 of all the CAI's tested side by side to date.
Old 09-09-2011, 05:34 PM   #7
kga10734
Don't Feed the Troll
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
kga10734 is offline   Reply With Quote
Old 09-12-2011, 04:51 PM   #8
starscream88
Looked at the tube today and also called to verify. Everything with it is fine, thanks everyone for the help!
Old 09-14-2011, 03:04 PM   #9
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
The best CAI on the market!
Kind regards,
Jordan
JDP Motorsports is offline   Reply With Quote
air raid, cai
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
BBK Shorty Header Dyno Test Today!!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-25-2021 09:58 AM
Engine heat/Cold Air intake FosterSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 06-01-2011 09:14 AM
LSR Cold Air Intake + SCT Tuner - Special Pricing Meister@Torq V8 Bolt-Ons & Tunes 2 05-03-2010 09:06 AM
K&N TYPHOON Air Intake Kit - On Sale ~ Bolt on 18+hp! Circuit Motorsports V8 Bolt-Ons & Tunes 101 02-06-2010 01:16 AM
