![]() Drives: 2010 2ss silver/cyb Join Date: Feb 2009
Camshaft Replacement
Do the heads have to be removed to access the lifters on an LS3? Or can you get to them just by removing the intake manifold? I plan on changing the cam for a high perfomance one and was just curious. Thanks
#2 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
I believe you cant access them without pulling the heads
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
![]() Drives: 6 camaros Join Date: Feb 2009
no need not even the intake. But you do in most cases need new valve springs.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
2G1FT1EW0A9118618
Drives: 2010 Camaro 2SS Black/IOM M6 Join Date: Dec 2008
Well first you must remove the caneuter value and then remove the Flux capacitor and then the camshaft should be no problem getting to.
His seafaringness
Drives: yugo Join Date: Mar 2009
do you need new valve springs with ls hotcam? can you put z06 cam in ls3 though?
#6 |
![]() Drives: 1000HP 2010 SSRS Join Date: Jan 2009
For cam replacement: Pull the rockers, rotate the cam once and remove. The lifters hang in place. For lifter replacement, head removal is necessary. And yes, make sure you change springs to match the cam (which can be done without head removal)
#7 |
![]() Drives: ex-500hp v6 mustang Join Date: Oct 2008
#8 |
2G1FT1EW0A9118618
#9 |
Thanks, I thought the lifters would drop down once the cam shaft was removed.
#10 | ||
Truth Enforcer
he's talking about the lifters DURING a cam swap. if you have to pull the heads. in this case, you do.
#11 | |||
Truth Enforcer
now if you are swapping the lifters, then you need to pull the heads here's a shot of the lifters in the retainer ![]()
#12 |
Drives: 2016 Camaro SS Join Date: Jan 2009
Just don't let them sit for too long or they can fall down.
18, 19, & 20" replacement tires ... | dougmac | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 03-29-2009 05:27 PM |
BMEP-Or why you only need 1 camshaft | rayhawk | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 12-03-2008 12:28 AM |
Question re LS7 replacement. Will dealer credit for LS3 engine? | upheval | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 11-24-2008 10:55 AM |
Exhaust replacement | ljustin293 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 11-07-2008 07:48 PM |
