Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
Aftermarket wheel compatibility
I've seen everyone posting pics of the wheels they want to purchase to customize their ride, but here's a question that I think a lot of people are overlooking.
What needs to be done to aftermarket rims to make them compatible with the Tire Pressure Monitoring system in the Driver Information Center? I can see this potentially being a big issue with people. |
Rolling along...
There shouldn't be anything that needs to be done other than to swap the TPMS sensors from the stock wheels to the aftermarket wheels. They just replace the valve stem on the wheels. Discount Tire did the switch on my Expedition when I went from stock 17's to aftermarket 20's. No big deal.
This is only a problem if you buy your wheels through the mail with the tires already mounted. If you buy the wheels through the mail/internet and have new tires put on at a local shop, they can make the switch for you. |
Ah, see, I've never had a vehicle with the tire pressure monitoring system, so I wasn't aware how easy/difficult it would be to switch.
Thanks!
Weekend Rockstar
Drives: Depends on the day... Join Date: Mar 2008
Good answer Rolnso, the only thing you forgot is that different wheels and tires require different inflations, so you would have to take the vehicle back to the dealer to have them reprogram your TPMS (that might be a new acronym...tire pressure monitoring system) to your new wheel/tire specs. Also, GM does not recommend you use wheels and tires that are not designed for your vehicle. This doesn't stop most people, but if you put on new wheels and tires and something goes wrong with your suspension, there's a good chance the dealer would be able to tie that in with your swap, and therefore void your warranty.
Rolling along...
Chevyrocker - Good point. I made the assumption that most people will run tires that fall within the standard inflation ranges already setup in the onboard computer. But you are correct, if you run tires that use a PSI outside of the acceptable range, then you will have to get the TPMS values reprogrammed by your dealer.
As for aftermarket wheels voiding your warranty, I suppose that's possible but I've never heard of that happening to anyone but the people that also jack with the suspension (off-roaders, air bags, etc...). |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 95 civic Join Date: Apr 2008
#7 | |
Rolling along...
http://www.breyton-export.com/articl...iew/301/1/201/ |
#8 | |
![]() Drives: 2016 2SS Camaro, 2017 Acura Join Date: Nov 2008
GM tire/wheel warning
2016 2SS, Auto, Garnet Red, Black Interior, Magnetic Ride, Performance Exhaust, and Nav.
Past highlights: 2013 2LT/RS, 2010 pre-order Camaro 2LT,1969 Chevy Malibu, 1972 Plymouth 'Cuda, 1972 Pontiac GTO, 1979 Turbo Buick Century. 'See the USA in your Chevrolet...' Dinah Shore, 1952: http://www.youtube.com/watch?v=KGZvQoPxhNs |
#9 | |
![]() Offset?what offset does the camaro have
#10 | |
![]() Drives: 2010 VR 2SS/RS A6 Join Date: Oct 2008
Intelligence plus character that is the goal of true education.
BrianC. :flag2: |
#11 | |
Rolling along...
We have yet to find out what the stock offset is for the Camaro.
#12 |
Rolling along...
I sent a PM to Number 3 to see if this is possible for you to do yourself in the Camaro or if you really do have to go to the dealer.
#13 | |
Drives: Anything I want Join Date: Oct 2008
Not true.We have had them for a while.Only problem is that ours are specific to the Z-28.The Z-28 would have had 20x9.5 front and 20x11 rear 305-35 20 and 275-40 20 front. Btw-Currently our wheels only come in the above size. |
#14 |
i just found out they fit the g8 gt
does that help me at all?I wish i knew more about this stuff
| Question: Cars only driven by one wheel? | JMROD | General Automotive + Other Cars Discussion | 17 | 08-29-2010 05:04 PM |
| 2SS Silver Ice Metallic at ATL Car SHow | Cmurf_SS | Camaro Photos | Spyshots | Video | Media Gallery | 40 | 11-09-2009 10:38 PM |
| Steering Wheel Pics Request | ihc95 | Camaro Photos | Spyshots | Video | Media Gallery | 9 | 02-23-2009 03:18 AM |
| aftermarket companies listening? | boxmonkeyracing | 5th Gen Camaro SS LS LT General Discussions | 24 | 12-14-2008 12:10 AM |
| Current wheel & design,just an observation | nitrokid | Wheels and Tires Talk Sponsored by The Tire Rack | 5 | 07-25-2008 01:33 PM |
