Old 09-17-2011, 07:52 PM   #1
CAMAROKILLS
Drives: 2010 CAMARO/1966 V8 Mustang
Exclamation TRIFECTA TUNER UNDER $400..?
So im new to this forum. I been looking for a tuner for my V6 camaro but I see there is no legit tuners for it other than Trifecta which you have to return when you upload it to your car and Hypertech which only adds 4HP while Trifecta states they add +20 HP. I found this website http://www.rawamericanmuscle.com/pro...e/Default.aspx
that sells Trifecta tuning for under 400 dlls.
what do you all think of this? you think I should buy it?
I also plan on putting my 3.73 gears i bought and some rims im currently thinking of getting. My car is completely stock other than a BBK cold air intake.
CAMAROKILLS is offline   Reply With Quote
Old 09-17-2011, 08:03 PM   #2
chabbz182
Drives: 2011 Rally Yellow SS Camaro
I found a trifecta tuner in garland, tx. Cost me $200. I think you should look around for another tuner. Check the trifecta website they may have one closer to el paso.
chabbz182 is offline   Reply With Quote
Old 09-17-2011, 08:09 PM   #3
CAMAROKILLS
yeah ill check up on that. thanks
have you seen any improvements on your car?
Old 09-18-2011, 01:24 AM   #4
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
you can buy Trifecta's cable outright(and have to use a laptop with it)... I have one
Vince is a good dude, and his tunes are no gimmick, he is a very good tuner
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 09-18-2011, 01:55 AM   #5
chabbz182
Yeah you will notice the difference and the ghost cam with the tune makes it sound oh so sweet.
Old 09-22-2011, 01:25 PM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Hi CK,
I got the tune from Trifecta on the handheld just like the one you're looking at. I've also already got the 3.73 gears and the usual assortment of other mods.
I Love it! It has worked great for me. The tune greatly improves response thru the midrange and has a much better top end end rush-esp with the lower gears- 3rd gear is a canyon carving moderate to high speed thrill ride (watch those RPM though, I think Vince must have done away with my rev limter. Saw at > 7K the other day and still pulling hard!)
However you must have the majority of your mods in place before you get the tune. The handheld tune is a one time deal so if you wait to change your gears, you have to order another tune to correct your speedo (it wil be 12.5% off with 3.73's) Also with the handheld option, there is no way to return your tune to stock for service at the dealer and you risk a voided warranty.
Trifecta's tune claims a 13hp gain on top from a stock car, but most people with mods have seen about 6hp. Both Trifecta and Hypertech show impressive gains at low to mid RPM, where we all usually drive.
Hypertech wasn't available when I got mine, but with the power gains and versatility it offers: change your tune as you make your changes, speedo correction for gears or rim size changes, and return to stock at the press of a button- I would have given it strong consideration.
Old 09-25-2011, 11:18 PM   #7
CAMAROKILLS
Whoe is Vince?
can i get his number?
Thanks
Old 09-26-2011, 12:02 AM   #8
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
got anyone nearby austin? please???
kenkartasasmita is offline   Reply With Quote
Old 09-26-2011, 12:05 AM   #9
CAMAROKILLS
[QUOTE=Ventmaster;3787853]Hi CK,
When i put my gears on, i want to get the trifecta tuner. question is i also want to get twentys(rims) on it later. how will that work? Will i more tan likley have to get the tuner again right?
im going to be racing a 2011 5.0 V8 mustang and the driver keeps talking a lot of smack and i need all he help i can get since im a V6 with just a bbk cold air intake
what else can i do guys?
Old 09-26-2011, 01:17 PM   #10
Ventmaster
Ventmaster's Avatar
I believe the circumference of the stock wheels, 18,19, or 20 inch is the same because they use tires with a taller side wall on the smaller wheels-so 1 rotation of the wheel covers the same distance regardless of your wheel option.
Therefore, once you get the computer tuned to correct for 3.73 gears, you can use any stock wheel/tire combo or other aftermarket wheel/tire as long as you don't stray far from the stock circumference.
Although the 3.73's will help you get out of the hole faster, don't put alot of $ on that race. If you get a jump on a 5.0 2011 model, you would have a chance, but if he knows you're coming-well we're good for a V6, but I doubt you can take a 5.0.
Old 09-26-2011, 05:47 PM   #11
CAMAROKILLS
Although the 3.73's will help you get out of the hole faster, don't put alot of $ on that race. If you get a jump on a 5.0 2011 model, you would have a chance, but if he knows you're coming-well we're good for a V6, but I doubt you can take a 5.0.[/QUOTE]
Thanks.
If by all fails, Ill but some nitro into it
I was looking at at least 90hp more to the wheel
Old 09-26-2011, 09:40 PM   #12
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I would recomend the cable so you can data log and tweak your tune free of charge over time.
OOLIE is offline   Reply With Quote
Old 09-27-2011, 05:32 PM   #13
CAMAROKILLS
Yeah. thanks for the info
Your car looks pretty tight.
Old 09-27-2011, 09:24 PM   #14
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Thanks
You will be happy with the tune.
FS: TRIFECTA TUNER CABLE Jshadow V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 5 06-29-2011 04:59 PM
TUNER GALLERIA Chicago Car Show @ Donald E Stephens Convention Center! CarNutzCustomz USA - Great Lakes 0 01-23-2010 11:40 PM
