Old 09-18-2011, 01:01 PM   #1
TDevilsG
TDevilsG's Avatar
Drives: 2013 2LT Victory Red LFX
Best Cold Air intake for value? 2012 V6
Hi Everyone, I'm thinking about picking up a cold air intake for my 2012 V6 1LT Camaro. Can anyone recommend a good one based upon value and overall price?
http://www.************.com/2010-cam...r-intakes.html
Thank you for the help!
TDevilsG is offline   Reply With Quote
Old 09-18-2011, 01:33 PM   #2
StoopDude
StoopDude's Avatar
Drives: 2011 Camaro 2LT RS
Get the airaid I got one installed from JDP motorsports on Friday we did a before and after dyno I picked up 13RWHP on 87 octane gas. Go to www.jdpmotorsports.com or call them ask for Jordan! He is the owner great guy!!
StoopDude is offline   Reply With Quote
Old 09-18-2011, 07:32 PM   #3
KMPrenger
KMPrenger's Avatar
TDevil...be advised before you order anything that the intakes designed for the 2010 and 2011 V6s will not work for the 2012 LFX engine.
Unfortunently I'm not sure if there are even any cold air intakes available for the 2012 V6, but I'm sure there will be soon. Just do your homework and you will be fine!
Old 09-19-2011, 11:24 AM   #4
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Here is what we offer our customer:
Cold Air Inductions, Inc. intake systems benefits:
: Tig welded aluminum air box (high luster finish reflects radiant heat)
: Insulated air box (this adding another layer of thermal (convection) protection)
: Aluminum lid with stainless steel ¼ turn fasteners (fast filter removal)
: Viewing window for fast easy filter inspection.
: High Luster ceramic coated intake tube (coated inside and out, yet another layer of thermal protection)
: Smooth bore (88.9 mm) intake tube construction (this minimizes bends and restrictions within the system)
: 8” V-stack air filter with built in velocity stack (helps reduce turbulence for truer MAF reading)
: 8 layer air filter (maximizing filtration for prolonged engine life
: LIFETIME WARRANTY
We have sold thousands of intakes, have thousands of happy customers, and incorporate design features that make our system a true Cold Air Intake. We see great #’s on the Dyno as well as the track, and can keep our intake temps within 2 degrees of ambient air due to our design features.
Check out these links as well:
Testimonials Video - http://www.coldairinductions.com/testimonials
3D Filter Video - http://www.coldairinductions.com/air-filters/filters-in-action/
Let me know if you have any questions, I would be happy to help!!
Sales @ CAI Inc is offline   Reply With Quote
Old 09-19-2011, 12:34 PM   #5
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Contact manufacturers directly(there's plenty that are posting on here) and ask them if they've got one yet that works with the 2012. If they tell you there's will work even if it's a 2010-11 ask about a return policy.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 09-19-2011, 12:53 PM   #6
TDevilsG
TDevilsG's Avatar
Thank you everyone!
Sent from my DROID3 using Tapatalk
Old 09-19-2011, 06:24 PM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
Anything we sell is a pretty good value. We have some rock bottom pricing. I'd recomend a Roto-Fab or CAI intake. We seem to have the most happy customers with them.
Juiced1 is offline   Reply With Quote
Old 09-20-2011, 03:51 PM   #8
av3206
Drives: Camaro
i am getting conflicking info that nothing is ready for 2012......can anyone put links up to air flow for the 2012 v6..........
av3206 is offline   Reply With Quote
Old 09-20-2011, 06:09 PM   #9
Infernoo
Infernoo's Avatar
Drives: '11 IOM 2LT/RS
I've seen nothing for the 2012's yet.. that's a whole different ECU than the '10 and '11s
Infernoo is offline   Reply With Quote
Old 09-20-2011, 06:37 PM   #10
Gregwardocanibal
Drives: Black 2012 Camaro LS
The issue is the MAF ( Mass Air Flow) sensor which tells the engine how much air is going into the intake is changed. Literally every other part is the same. The screw pattern was changed, but as of right now that looks like thats all that was. Since all the existing CAI are the old screw pattern, you can't use them on your car. I am working on finding a quick-fix or some intake that might work. I'll message you as I get stuff figured out/as i know ore (Working with Roto-fab right now to try and get an intake on my 2012 2LS)
Gregwardocanibal is offline   Reply With Quote
Old 09-20-2011, 10:44 PM   #11
AKA-22
AKA-22's Avatar
Drives: ELLE-1
yea im waiting for that info also!!!
AKA-22 is offline   Reply With Quote
Old 09-22-2011, 10:16 AM   #12
av3206
Drives: Camaro
if its just a few bolts i would hope the fix is quick..... but i guess they need to get their hands on a new one to test it out
Old 09-22-2011, 10:43 AM   #13
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
I love how Vendors just roll in here offering products that are baselined for 2010 and 11 models but have no info if those same products work with 2012 models.
Vendors: Please read OPs before posting about products that may or may not be available for the new engine. You are walking a thin line here called "misleading"
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 09-22-2011, 10:53 AM   #14
Blade
Blade's Avatar
This.
Start contacting manufacturers like Bill @ CAI, Injen, AirRaid, Vararam etc. They may even be able to use you as a test mule to figure if the existing products work on the 2012s. Or they might already have something in the works.
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
Fastlane Pipeline Cold Air Intake at Phastek Performance Jason@Phastek V8 Bolt-Ons & Tunes 2 03-30-2016 08:19 AM
CAI Air Intake Systems V6 V8 Polished & Black Free Shipping ! Unique Auto Depot V6 Bolt-Ons & Tunes 5 12-03-2011 03:59 PM
Help You and Your Ride Breath Easier GmPartsDirect.com V8 Bolt-Ons & Tunes 0 03-30-2011 05:49 PM
\\\\\\K&N INTAKES BLOW OUT SALE +FREE SHIPPING////// GmPartsDirect.com V8 Bolt-Ons & Tunes 2 03-29-2011 05:27 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
