Old 09-21-2011, 01:47 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
CEL - P0174 code
I've had my car tuned for about 5k miles now with no CEL. All of a sudden I got a CEL that I noticed last night. Ran by O'Reilly this afternoon and the scan tool said "P0174 - System Too Lean (bank 2)".
Now, I will also say that on Monday I had some diff bushings put in and we had to remove the exhaust to allow the diff to come down. My cat-back is tack welded so we removed it from the LTs back. In order to do that we removed the O2 sensors out of the cat and left them hanging until we were done.
I cleared the code with the scan tool and it didn't come back but I've only driven it maybe 10 miles and didn't get on it or anything.
Anyone know what that code is saying. Doesn't it have to do with the O2 sensor for the cat?
Build Journal
Old 09-21-2011, 05:48 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
use your tool to data log and then post the results
Parag is offline   Reply With Quote
Old 09-21-2011, 07:17 PM   #3
montreal2010yellow
montreal2010yellow's Avatar
You need a tune...
Old 09-21-2011, 07:35 PM   #4
caverman
caverman's Avatar
I don't have a scan tool. I just went down to O'Rielly, gave them my drivers license, took the tool out to my car and ran the scan. When I was done I gave it back less than 10 min later.
Originally Posted by montreal2010yellow View Post
You need a tune...
My car has been tuned for over 5,000 miles and was tuned by ADM Performance. The tune is not the issue.
I'm hoping it was a fluke thing. I'm going try to get it up on a lift this weekend and re-check the exhaust and O2 sensors to make sure they didn't come lose.
Build Journal
Old 09-21-2011, 07:40 PM   #5
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
It does have to do with the cats... The one on the passenger side is going bad... Had to change mine out too....
MARINE1991 is offline   Reply With Quote
Old 09-21-2011, 07:42 PM   #6
MARINE1991
MARINE1991's Avatar
Oh o2 sensors go bad with long tubes... Since changing them out no issues...
Old 09-21-2011, 09:45 PM   #7
caverman
caverman's Avatar
Drove about 40 or so miles tonight. Got on it hard a couple times. No CEL so far. I'm hoping the CEL I got was kind of a fluke.
Build Journal
Old 09-21-2011, 09:52 PM   #8
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
I have had this code a couple of times....I've got long tubes, off road pipes, CAI, o2 bung extenders, no tune....I've just cleared the code...I figured a tune would help eliminate it?
KnightRiderSS is offline   Reply With Quote
Old 09-21-2011, 10:02 PM   #9
Zippy
Drives: 2006 Silverado 1500
That means that the passenger side was showing lean quite possibly from an exhaust leak, loose O2 sensor, or other problem. I would scan it to see if both banks are lean or just the one.
6 time F-body owner. Currently a truck owner though.
2006 Silverado 1500 RCSB: 13.59@100 2.0 60' in full street trim on 20's. 5.3L n/a.
Zippy is offline   Reply With Quote
Old 09-22-2011, 07:43 AM   #10
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
I would agree given the fact that this happened after the exhaust was removed. I would check for an exhaust leak around any of the non welded connection. It should be be pretty easy to spot look for black soot or carbon around those joints.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 09-22-2011, 12:42 PM   #11
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Its been my experience that those only take about 30miles to re-occur if they're gonna.
Hopefully you just got a little contamination on the end of the sensor (anti-seize) and now its burned off.
Its not uncommon for those sensors to "drop a thread" on removal and create a leak, so that might be one other thing to check if it does come back.
Good luck
Old 10-31-2011, 09:19 AM   #12
caverman
caverman's Avatar
Ok...so this error code has been coming back on me. It's happened twice now since I last posted this thread.
I've check my exhaust and the connnection of the sensor and it seems to be good. I have a feeling it's either a bad sensor or cat. I say that because it just randomly comes on. Prime example is that it's been off for a while and last Friday I took it out to the drag strip. After a good 4 or 5 runs I had no light. Then two days later I start it up and the light comes on again. I was initially thinking that there was some kind of exhaust leak and it wouldn't show it's ugly head until I really went WOT on a cool night or something. Well, that theory went out the door.
So...what would you do? Should I go buy another sensor (assuming I can and hopefully they aren't a ton of money) and give that a try? Then if that doesn't work look at replacing the cat....which is probably alot more expensive?
BTW: Do you think the dealer is the only place to get a sensor from?
Build Journal
Old 10-31-2011, 09:27 AM   #13
caverman
caverman's Avatar
Anyone know what the name of the rear senor is called? I went to GMPartsHouse and did a search. The only thing I could find that was close to what I thought it might be is a Oxygen Sensor. It is under the Powertrain | Electrical section, has a front and rear sensor listed, and is about $45. There is no part number listed. Do think that's the one?
Build Journal
Old 10-31-2011, 10:43 AM   #14
MARINE1991
MARINE1991's Avatar
YEP thats the one, if you had a tune the rears should have been turned off and you should only be running the front ones...
One possible solution to CEL P0430 w/ JBA midpipes Goliath Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 01-10-2011 07:55 PM
Advanced Auto Parts online coupon code crzycicada Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 12-17-2010 09:57 AM
Did you get an "EVENT HISTORY" for YOUR car? CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 24 11-21-2010 11:20 AM
Another LT Headers and CEL for Emissions kauffjd3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-29-2010 02:54 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
