Old 09-21-2011, 06:35 PM   #1
siriusdish
Drives: 2010 Camaro L99
Corvet rims 18"
What are the Cheap 18" rims called? I can not find the thread. Thank you
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 09-21-2011, 06:43 PM   #2
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
the vette rims that fit the camaro ? are the front zo6 18x9 or the grand sport 18x9...have to be oem as reproductions have incorrect offset..
mikepage0007 is offline   Reply With Quote
Old 09-21-2011, 07:57 PM   #3
siriusdish
The Knock off 18" for DR's/. I seen a thread before and now can't find it.
2010 L99
Old 09-21-2011, 08:23 PM   #4
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2013 1LE
this one??
http://www.camaro5.com/forums/showth...rag+wheels+set
Black 2013 1LE - Bolt ons - Heads - Cam- Suspension - Built by Jrod - Sorian Tuned
shadow09 is offline   Reply With Quote
Old 09-21-2011, 08:52 PM   #5
mikepage0007
Drives: 2010 camaro
just make sure they have the 40mm offset..and just so everyone knows..no vette wheels are a exact match..vette wheels have a 121mm stud pattern and the camaro has a 120mm pattern..they will fit , but they tweak the studs just a hair,..you will have no problem as the camaro studs are 14mm in size and , have plenty of strength..but when racing, i would retorque after every run, it is not unheard of them loosening...takes 2 minutes and your car is cooling anyhow..
Old 09-21-2011, 09:06 PM   #6
Eric Baker
Drives: Black/Black 2SS/RS 6M
Just ordered some off Amazon. I'm gonna use them next saturday(as long as their here in time) then look into having the holes machined so they bolt up correctly.
Eric Baker is offline   Reply With Quote
Old 09-21-2011, 09:44 PM   #7
siriusdish
Yes that's the thread... Was running it by my Dad for next year as he keeps waring the DR out on stock rims. Could they be swapped at home then drive to the track with the 18's with the stock 20's in the front?
2010 L99
Old 09-21-2011, 09:52 PM   #8
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2013 1LE
Yeah you can drive with the 20's up front and the 18's out back. Just make sure the tire height for the rear is within factory. Let's say you get the 18x10.5 wheels, the tire that you should run would be 305/45/18 or 315/45/18.
here is a thread on recommended tire sizes: http://www.camaro5.com/forums/showthread.php?t=62838
Old 09-21-2011, 10:00 PM   #9
siriusdish
sweet, thank you!
2010 L99
Old 09-21-2011, 10:03 PM   #10
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2013 1LE
sweet, thank you!
anytime
18" rims for cheap? aron77 Wheels and Tires Talk Sponsored by The Tire Rack 4 08-18-2011 08:44 PM
WTT/WTS 1LS 18" rims and tires. xpanda305x Wheels / Tires 0 10-18-2010 02:17 PM
FOR SALE OR TRADE OEM 18" ALLOY 5 SPOKE RIMS TIRES WHEELS VT2CA Wheels / Tires 1 10-11-2010 09:15 PM
18" rims wanted dlynds Canada 1 08-29-2009 06:38 PM
wanted 18" rims 2010 Camaro dlynds Wheels and Tires Talk Sponsored by The Tire Rack 4 08-23-2009 08:32 PM
