Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California > Local Marketplace
Old 09-25-2011, 09:18 PM   #1
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
2 EDGE PERFORMANCE Pure Power Lifetime Oil Filter
2 EDGE PERFORMANCE
Has the Pure Power Lifetime Oil Filters for sale
AMERICAN MADE
6061 T6 Billet Aluminum
100% Filtration through T304 Stainless Steel Media
Direct Replacement
Never buy another Oil Filter
Easy cleaning and monitoring of Engine wear
No more paper fibers to travel back into the engine oil system
Available for the GEN5 Camaro 6.2 L99/LS3
Call or message 2 Edge Performance
949.515-2088
$219.95
The Best investment that you can buy to protect your Engine
No more stamped steel cartridges held together with
silicone and cardboard.
A True 100% Filtration Filter
MRGOODWRENCH3 is offline
Old 09-25-2011, 10:00 PM   #2
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Chris this is interesting... need more details.. like how does it never need changing Looks good and interesting..
MARINE1991 is offline
Old 09-26-2011, 12:38 PM   #3
MRGOODWRENCH3
The oil filter is removed during the oil change and disassembled. The element and magnets are cleaned out and then reinstalled. The filter element is made of stainless steel not paper.
Old 09-29-2011, 05:02 PM   #4
MRGOODWRENCH3
Great way to keep that engine clean and running great. Order your oil filter today.
Old 10-12-2011, 01:23 PM   #5
MRGOODWRENCH3
Call today to order the best oil filter on the market.
Old 10-17-2011, 09:36 PM   #6
MRGOODWRENCH3
Call today to place your order.
Old 10-17-2011, 10:13 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
does it have a pressure relief valve built into it like the factory pf48 filters
camaro1 is offline
Old 10-20-2011, 12:38 PM   #8
MRGOODWRENCH3
Yes it does.
2 edge performance, oil, oil filter
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
