Old 09-28-2011, 05:31 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
lsx7heads/whipple
anyone done a whipple with lsx7 heads? it has been brought up that the whipple runners are slightlty different for the lsx7 ports...trying to see if anyone has done 1 yet , and what info i can find on this b4 we start build..thanks.. i know the whipple is designed for ls3 heads..
mikepage0007 is offline   Reply With Quote
Old 09-28-2011, 05:44 PM   #2
Jessika
Drives: Anything Blown
I don't know about the whipple, but we have done quite a few Magnuson LSX/LS7 5th gen Camaro kits.
Jessika is offline   Reply With Quote
Old 09-28-2011, 05:51 PM   #3
BlownChevy
Drives: 2015 1SS RS 1LE
Mike I have installed a few Magnuson Superchargers on Camaros equipped with LS7 heads. If you are interested in discussing your options feel free to call me!
BlownChevy is offline   Reply With Quote
Old 09-28-2011, 07:40 PM   #4
Mike@Whipple
Whipplecharged
Mike@Whipple's Avatar
Drives: 1956 Chevy 3100
Mike, we do have an LS7 manifold for our C6 Vette kit that will work just fine with our 2.9L Camaro kit. We have sold quite a few Camaro kits with the LS7 manifold option.
Mike@Whipple is offline   Reply With Quote
Old 09-28-2011, 07:48 PM   #5
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Lol....it's like a piranha pool in here sometimes.
HufferSS is offline   Reply With Quote
Old 09-28-2011, 10:38 PM   #6
Tyler@ExtremePerformance
Tyler@ExtremePerformance's Avatar
Drives: 2007 Trailblazer SS
Nice Mike just need to get that manifold boom solved! Thanks Whipple!
Tyler@ExtremePerformance is offline   Reply With Quote
Old 09-28-2011, 10:46 PM   #7
BLACK10
BLACK10's Avatar
yeah, but you do get info quickly
Old 09-29-2011, 12:24 AM   #8
mikepage0007
Drives: 2010 camaro
thanks for the heads up mike...quik response...also thought that as many people are now going lsx , it might help others get more information on this setup...was gonna call you on that tomorrow, but thought i would field the question to some of your great whipple vendors...will buzz you out..thanks
Old 09-29-2011, 09:04 AM   #9
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Hendrix-Engineering is offline   Reply With Quote
Old 09-29-2011, 10:58 AM   #10
Jessika
Old 09-29-2011, 11:58 AM   #11
AutoX
Drives: Camaro
ls7 heads are a raised runner type.
If you put an ls3 charger on it, you might not get the correct alignment.
It will make power... but it will NOT make all that it could.
AutoX is offline   Reply With Quote
Old 09-29-2011, 01:57 PM   #12
Mike@Whipple
Whipplecharged
Sorry, I should have cleared this up a bit in my last post.
If you tried to put our Camaro LS3/L99 kit onto an LS7 headed motor, it would not line up correctly and the bolt holes will be off.
Also, someone with an existing Whipple LS3/L99 kit will not be able to simply purchase a new LS7 manifold and bolt it on. The mounting locations on the blower case are different for the LS7 manifold as well in order to keep the bolt holes out of the intake runners for optimum air flow numbers from port to port.
Now, there is a way around this without having to purchase a new blower assembly if you are doing a build with the LS7 heads and already have the kit. A good dealer of mine CBM Motorsports makes and sells billet adapters to fit between the manifold and heads to make a smooth transition between the L92 manifold and the LS7heads. These will work with LS3/L99/L92 manifold.
Old 09-29-2011, 03:44 PM   #13
great explanation mike, mike will be thrilled you have a way to correct this ...
Old 09-29-2011, 05:02 PM   #14
mikepage0007
Drives: 2010 camaro
yea, mike will send you a pm so you can get me in touch with your dealer..thanks for looking out..
