Old 10-08-2011, 02:24 PM   #1
The Shadoww
Black on Black on Black
The Shadoww's Avatar
Drives: 2011 Camaro 1LS
Send a message via Skype™ to The Shadoww
Question CCFL Tail Lights
Hey guys, i need a little help. I have the CCFL Afterburners from AACstyle on my car, they are already in the lamps and mounted back on the car. My issue is that the instructions they sent me are for the older model of Afterburners.
Old ones: The old ones tell you to connect to the parking light (purple) and ground for each lamp (black), pretty simple.
New Ones: The new ones however have an inverter for each side. The CCFL Lights plug into the inverter then the inverter has a ground and a power wire.
Unfortunately for me the wires that connect to the tail lamps are a different color than the ones that connect to the main set of wires. Instead of there being yellow/black, Purple, and black, there is tons of new colors (none of which are purple or black).
Does anyone know what color i'm supposed to connect to?
Would it be okay for me to just look and see which ones connect to the purple and black at the plug? I do not know much about wiring. Various set backs has tuned this 4 hour job into a (already) 9hour job.
Thanks for any help or links or whatever.
The Shadoww is offline   Reply With Quote
Old 10-08-2011, 03:22 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Contact AAC tech. They will help you for sure. Just call and be like can I be forwarded to a tech regarding installation of 2011 camaro afterburners =)
Old 10-08-2011, 03:52 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
You need to look at the plug that connects into the tail lamp. You should see a purple wire. Plug the positive wire from the inverter into that purple wire. Then connect the black wire from the inverter to the black wire in that same wire bundle. There should be 3 wires in the bundle going to the tail lamp. A purple, black, and then a silver one I believe. Either or you just need the purple wire and the black wire.
Click to view my build thread
Old 10-08-2011, 08:23 PM   #4
The Shadoww
@ihoveacamaro I did call, their tecs are out until monday.
stieger, i did that but it wouldn't turn on. Btw there is only one inverter per 2 lamps. Is this the same Afterburners you have?
Old 04-28-2012, 11:55 PM   #5
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
please post whatever they sent you, I need it.
nikos30 is offline   Reply With Quote
Old 04-29-2012, 12:35 AM   #6
The Stig
The Stig's Avatar
Yes it is one inverter for each pair of headlights.
What do you need help with?
Old 04-29-2012, 09:15 AM   #7
nikos30
HT5 EastSide
nikos30's Avatar
the wiring instructions please
Old 04-29-2012, 11:27 AM   #8
The Stig
The Stig's Avatar
Red wire from inverter goes to the purple wire that goes to the harness connected to the bulb. That's the drivers side. Then for the passenger side I believe the wire is brown.
Old 05-01-2012, 01:51 AM   #9
The Shadoww
This is correct. I found that T-taps worked best. I'm sorry i forgot to come back to this post. To be completely honest mine aren't even in yet because i have problems. lol.
But Stieger is correct on the wiring.
ccfl, help!, tail lights
Blacking Out the Tail Lights, Head Lights, Side Lights. atlang3lo Cosmetics and Lighting Modification Discussions 12 04-03-2012 07:52 PM
Clear Lens Tail Lights - smoked kdoske Cosmetics and Lighting Modification Discussions 13 04-24-2011 02:55 AM
Full LED Tail lights? ZNOLMT Cosmetics and Lighting Modification Discussions 1 08-08-2010 06:10 PM
TAIL LIGHTS MotorCityCustoms Exterior Parts & Accessories 1 02-23-2010 01:11 AM
