Old 10-10-2011, 12:34 AM   #1
Yellow Camaro
Drives: 2010 Rally Yellow 2SS/RS
SS sometimes hesitant to start? "Open, then close drivers window"? What's wrong?
I have a couple of issues with my L99, which I believe are related but not sure what the exact problem is.
The car is occasionally difficult to start. On older cars I've had dead batteries, bad alternators....this isn't quite the same behavior. You turn the key, it sort of clicks once and sounds like it's about to fire up, but then doesn't. If it doesn't start normally on the first try, I turn the key back and try again....on the second try it either fires right up...or does nothing (no click, no start). Worst case scenario, it does fire up fine the third time. This doesn't occur nearly every time I start the car...but it's often enough to be annoying, doubly so if I have a passenger or I'm leaving a crowded place and a bunch of people are watching. If there's any variable involved, I do feel like this is MOST likely to occur if I'm starting the car shortly after turning it off (such as after running into a store). Some sort of "heat soak" crossed my mind, as I know this was an issue with previous generations. I'm not sure if there's a warranty solution for this....and not 100% heat soak is the issue since it sometimes happens as much as an hour after turning the car off. However, NEVER first thing in the morning or the end of a workday. Could just be a coincidence...
I also have been getting a message that says "Open, then close driver's window"...this has happened a few times, and I'm not sure if the correlation is 100%- but it often seems to be after one of these weak start-ups.
Twice when this happened, the little indicator light on the gauge cluster in the shape of a lock was lit up until I shut the car off. I think this light is consistent with your alarm having gone off, or some sort of security issue. It's not on any more, but I think it's orange and has a car with a pic of a lock in front of it. I think the issue was related.
Yellow Camaro is offline   Reply With Quote
Old 10-10-2011, 12:55 AM   #2
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
Take the car to the dealers, most definitely if it's under warranty!
Old 10-10-2011, 10:36 AM   #3
qkslvr
qkslvr's Avatar
Drives: 2010 ABM 1SS M6 NON RS
The window issue sounds like a indexing issue… Did you disconnect the battery recently? Mine did that a couple times after I disconnected the battery for the long tube install. Check the terminal post connections make sure they are tight.
The no start thing, I'm not sure
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s
2018 GMC Sierra (Stone Blue metallic)
2016 Streetglide (Crushed Ice Pearl)
2018 Indian Scout (Bronze Smoke)
qkslvr is offline   Reply With Quote
Old 10-10-2011, 10:38 AM   #4
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Sounds like a battery issue? Get it to your dealer.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 10-10-2011, 02:42 PM   #5
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
May have something to do with the Body Control Module. You migt try disconnecting the battery for minute or so. You'll have to index the windows and set the radio again. If that fails take it to a dealer.
Cam 427 is offline   Reply With Quote
Old 10-10-2011, 05:19 PM   #6
2SS BUMBLBE
2SS BUMBLBE's Avatar
Drives: 2010 2SS/RS/L99
Best window index thread
I used method 1 in the below thread. Worked like a charm! Good luck.
http://www.camaro5.com/forums/showthread.php?t=70683
2SS BUMBLBE is offline   Reply With Quote
Old 10-10-2011, 05:20 PM   #7
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
u have a gremlin in the motor j/k
ipimpthisc is offline   Reply With Quote
Old 10-10-2011, 05:53 PM   #8
BLACK10
BLACK10's Avatar
Starter connection or battery post loose
Old 02-23-2017, 06:05 PM   #9
Mr Bobby
Drives: 2015 Camaro SS
tonight after working a 10 hour shift i went to my car and tried to start it, the display flashed then went off. I tried a second time then i got a message that the park assist wasnt available, trying a third time i got the window message but the windows wouldnt go down, i opened the drivers door the window did its normal 1/2 inch jog down, then i was able to roll the driver window down then up, it then wanted the passenger window done the same way, after that the display lit up with 0MPH and i could start the car, i took the car immediately to the dealer where it will spend the night. While driving at 40 MPH the car wanted the windows done again, so i did and all was well except for a check engine light, we will see what they find, i will post the result
Mr Bobby is offline   Reply With Quote
Old 02-23-2017, 11:18 PM   #10
Spec
Drives: 2010 Camaro 1SS LS3
Yep, sounds like a BCM issue. Had mine malfunction at around 85k or so. $600 to repair...
Spec is offline   Reply With Quote
Old 02-24-2017, 11:54 AM   #11
Mr Bobby
Turns out to have been a loose connection at the under hood fuse panel, glad it was simple
Drivers and Spectators Count - Camaro5fest II '11 garcmol 2011 Camaro5 Fest (II) 862 04-22-2011 09:09 PM
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-05-2010 12:49 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 02:20 AM
