#1 | |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
My latest DYNO the good and the bad..
As always I like to share my work with my fellow camaro gurus especially when it come to dyno numbers so here is another one for you guys.
So yesterday I went for another dyno run to establish my current number to ready for some porting work I am currently having worked on. Since my last "gas" dyno run the only addition I made was vmax ported TB and AEM brute force cold air inatke modded for ram air through a 6" velocity stack inlet. So to make the story short take a look at the last dyno vs yesterday's dyno. (yesterday's dyno is red/black and the older dyno is blue/green) Let me start with the good news . take a look at the AFR. The AFR are in the 10's!! rich rich rich, but if you look at the graph closely I still made torque and hp(avg of 13)all through out the board than pass 5k rpm I start losing power.Here is a better example from one of the run in data format. RPM x1000 hp ft-lbs Air/Fuel 3.10 138.49 234.64 11.21 3.20 144.31 236.85 11.17 3.30 150.60 239.68 11.14 3.40 154.85 239.20 11.13 3.50 161.59 242.48 11.14 3.60 168.36 245.62 11.11 3.70 173.14 245.77 11.05 3.80 176.31 243.69 11.04 3.90 179.35 241.53 11.03 4.00 181.97 238.93 11.06 4.10 187.47 240.15 11.13 4.20 191.37 239.31 11.14 4.30 195.11 238.32 11.17 4.40 198.15 236.54 11.21 4.50 200.59 234.12 11.21 4.60 203.54 232.40 11.12 4.70 209.11 233.67 11.01 4.80 215.13 235.40 10.89 4.90 221.49 237.40 10.83 5.00 225.11 236.46 10.90 5.10 230.99 237.88 10.97 5.20 233.86 236.20 10.95 5.30 235.28 233.16 10.95 5.40 238.79 232.25 10.99 5.50 239.66 228.86 10.95 5.60 243.52 228.39 10.95 5.70 245.77 226.46 10.86 5.80 247.77 224.37 10.76 5.90 250.02 222.57 10.75 6.00 252.21 220.77 10.77 6.10 255.85 220.30 10.82 6.20 257.72 218.32 10.93 6.30 259.39 216.25 10.92 6.40 258.98 212.53 10.92 6.50 261.49 211.29 10.93 6.60 261.95 208.46 10.86 You might ask why is this the good news lol. The answer is simple. Vince's tune usually put our AFR between 12.5-12.7 so If I still made power with my AFR in the 10's this mean I have more power to claim by correcting the AFR to it' proper range. ![]() Now the bad news is that I have to go back to the dyno and spend more money just so I can make sure that my AFR is in the correct range and I can make sure that I have the correct power figure to compare with once the porting is all said and done. Before I start getting questions or comments like "why is your dyno number so low with those mods"?? Let me first say that dyno is a measuring tool. The measurement is only good as to measure the difference from one mod to the next. There's no such thing as same exact figure for each and every dyno but maybe close, so if we are making 312 at the crank this does not mean we will see 265 to the wheels on every dyno each and every single time. The dyno I am using is the bigger 248x dynojet which is known to dyno stock v6 camaros in the 220-240 range to the wheels. Just a little viewing pleasure for you guys, or should I say listening pleasure Last edited by bmorecam; 10-12-2011 at 04:33 PM. |
KMK
Drives: Slow V6 Camaro Join Date: Jan 2010
pffff
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Anyways...bmorecam...thanks for sharing! So this compares to your last "gas" run with all the same mods except for your intake correct? Sucks that you have to spend money, but your doing it the way it should be done by making sure you get an accurate dyno reading before you throw on the ported intake which could really skew the results if you compared this run to one with a ported intake and a corrected tune. This is also another testimate to the potential power in the E85 tune. You had an extra 25 or so rwhp with that tune (not sure about the TQ numbers) in what I'm guessing was hotter weather...very impressive indeed.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
![]() ![]() ![]() ![]() Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
Dude - that is freakin awesome! So that was gas not E85? Why the switch up...are you trying to get a rough est for power from the 85 to the gas?
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
Prenger, I don't pay those special clowns any mind. I don't even know what "pffff" mean and thought it was just a typo lol
I seen the dude being negative in couple other threads but never thought he would come on my thread and show his emotion Anyhow, I'm just glad that everything is going the right way and not the opposite. With my AFR shifting to 10's and still gaining avg of 13 hp/tq throughout the curve is ok. At least I know I have more power to claim from 10's all the way to 12's
#6 | |
Ethanol is a different animal but I am keeping it all gas for the rest of the year. |
#7 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
PFFTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
YOU CALLL THAT POWERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR I DO Nice results man, love the vid, car is looking badass! Like you said, dont pay attention to the clowns. Those are some nice gains, and I think if im reading it right, only peak is off a little right? Anyways next dyno with E85 in the spring should be REAL nice!Dude I have to pm you my plans that I have with my car soon
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
#8 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
On thing I noticed is it doesn't look like they have SAE correction turned on... makes it tougher to compare pulls from different times/days...
#9 |
![]() Drives: 2011 Camaro V6 LS Join Date: Jul 2011
Thank you for sharing, nice gains throughout the powerband.
#10 | |
I think once vince get the AFR back on track I think I can see as much as 20-25 across the board and def even more out in open road at high speed. What I am liking about this the most is that my tq level is defenitely getting better. After this winter and when I go back to ethanol I am hoping by that time cams will be an option. Defenitely get with me
#11 |
Shark attack!
Hey bmorecam just thought i would tell you that I love your color scheme and nice results on the Dyno.
#12 |
The last time I checked their ASE calculation was off which is calculated through their weather station which is supposedly not working and stuck at the same exact report april or july. I have to check back with them the next time I go and see what is the deal with that. I always just do the calculation manually but in this case I guess it really won't do any good since the calculation will only net me peak numbers. I have to see the off peak numbers/graph especially when I am running as rich as 10's.
#13 | |
Lucky for me I do all the striping myself so I can kinda change as I wish.As far as the dyno, this is more of information than anything. Just getting ready to show you guys how much porting will net in terms of gain. Im just happy that I caught a power robbing problem. If one person can take this information and learn something new about how our car operate and how we can lose or gain then that is good enough for me. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
thanks for the info, and the time/money spent! it means a lot!
